Computer trouble???
Old Oct 27, 2007 | 10:06 AM
Buddy A's Avatar
Buddy A
Default Computer trouble???
I've got a 1997 C-5. It is running good but the gauges are acting weird. The Oil life is stuck at 55%, oil pressure is reading 129, keyless entery won't reset. Can someone point me in the right direction to get this solved?
Thanks,
Buddy
Old Oct 27, 2007 | 10:13 AM
DeeGee's Avatar
DeeGee
It could all be related if your battery is on its way out. Random electrical glitches can be battery related. Autozone will do a free on load check.
That said if you just got the car it could be 3 separate faults, all fairly common.
The Oil Pressure Gauge is easy. The Oil pressure sensor is renowned for being unreliable. Do a search and you'll find the fix. heres a thread which will help:
http://forums.corvetteforum.com/show...or+replacement
The RKE may just need retraining or the fob battery could be on its way out. Try here for the retraining procedure:
http://forums.corvetteforum.com/show...t=fob+training
With the oil life, 10% is about 1000 miles. How far have you travelled? You could reset it but you've then lost the 45% that its used.
Old Oct 27, 2007 | 11:12 AM
Buddy A's Avatar
Buddy A
Thanks. This is a friends car. He's here at the station with me today.
To Computer trouble???
