I just installed HID headlights on my 98 C5. Problem is when i got finished when you turn the switch off the headlights wont go down to you hit the brights on then back off real quick while the switch is in the off position. It sounds like the timing of the headlights is off or something is there a way to program them or any other suggestions to the problems. Please help ASAP
Try some punctuation and we may be able to help. Sounds to me like a ground issue. The other thing to checxk is fuse #6 in the passenger footwell. It controls the motors and its easy to blow the fuse.
Jdmvette is the Forum guru on HIDs. I'm sure he'll chime in if we can understand what's going on.
From: The United States of TEXAS www.corvettemotorsportsinc.com
St. Jude Donor '07-'08-'09-'10-'11
