Winter storage tire pressure?
Old Oct 27, 2007 | 07:25 PM
Tombone's Avatar
Tombone
Default Winter storage tire pressure?
Storing the car with the tires on the car in Onatrio Canada.
Tire pressure?
Thanks, Tom.
Old Oct 27, 2007 | 07:29 PM
Sheenadianah's Avatar
Sheenadianah
id store it around 35psi bc it will decrease in the cold anyways.
Old Oct 27, 2007 | 07:35 PM
Kamil D.'s Avatar
Kamil D.
How long are you storing the car for? the tire pressure is something to worry about but more I would worry about getting the tires flat spotted and the tires are gone be trashed why not just take them off?
Old Oct 27, 2007 | 07:46 PM
carlos93007's Avatar
carlos93007
Default Storing?
What is storing for the winter mean? I’m more worried about having enough fire extinguishers.
Old Oct 27, 2007 | 07:56 PM
moserbe's Avatar
moserbe
With the runflats you don't need to worry about it. If you're concerned, just park it with each tire on a 2" styrafoam panel.
Old Oct 27, 2007 | 08:11 PM
Tombone's Avatar
Tombone
Non-runflats.
Old Oct 27, 2007 | 08:14 PM
Kamil D.'s Avatar
Kamil D.
WHAT ???
Old Oct 27, 2007 | 08:23 PM
R Devil's Avatar
R Devil
Normal pressure is fine.
Old Oct 27, 2007 | 10:25 PM
I put about 5 pounds of extra air pressure in each tire when I store mine. That brings it up to 35 psi.
Old Oct 28, 2007 | 12:23 AM
Cart99's Avatar
Cart99
And, no, you don't need to worry about flat-spotting these days. If it does occur, it's temporary.
Old Oct 28, 2007 | 10:52 AM
rws.1's Avatar
rws.1
take them up to the max sidewall pressure
should be somewhere around 350KPa depending on the tire
Old Oct 28, 2007 | 10:54 AM
DeeGee's Avatar
DeeGee
Just wondering why anyone thinks it would matter providing the tire doesn't go soft
Genuine question.
Old Oct 28, 2007 | 06:59 PM
Cart99's Avatar
Cart99
Exactly. It doesn't matter.
Old Oct 28, 2007 | 10:04 PM
ROJ#79's Avatar
ROJ#79
I pump mine up to 45PSI and park on carpet squares for the winter.
Old Oct 28, 2007 | 10:14 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
Non Runflats here, I put 36 psi in them for storage. I have not had a "flat spotting " problem in 4 years of storing the car.
To Winter storage tire pressure?
