Lug Nut Key
Old Oct 29, 2007 | 01:37 AM
BATM4N's Avatar
BATM4N
Sometimes we overlook the obvious so here it is: Did you open the trunk and take off the square door on the left floor bottom? This is where it would of been stored with the paperwork of the company that made it. I am not referring to the big door in the middle.
I've read threads where some have cut them off but may damage the wheels a bit.
Old Oct 29, 2007 | 01:42 AM
DeeGee's Avatar
DeeGee
Originally Posted by CMC1998
You may be correct on the valve stem caps. I can't believe Chevrolet could use something so cheap.
Other than photoshop, how can you get to post pics here directly ?
Digressing but the OEM caps should be metallic. Its the antenna for the TPS.
