PFADT = Phenominal
Old Oct 29, 2007 | 05:43 PM
env00's Avatar
env00
Originally Posted by Z28STYLE23
Initially I lowered the most on stock bolts without any bushing cutting on the front or anything in rear. But still wasn't low enough for me. I hate wheel gap. So I had my car ludacriously lowered, my completely removing the bolts in the front and lowering bolts in the rear.
Like this:
Which looked great. But when driving on the freeway it would bottom out at certain areas, get real bouncy on uneven roads, real floaty at freeway speeds and when hitting bumps in mid turn you definetely didn't feel good at all, alittle scary. So quickly I looked at other options, I still want it low but I want to feel safe. So after speaking with several guys withe PFADT coil overs I decided to try it and SOOOOOOOOOO glad I did. That car is alittle higher then before but not much and it rides better then it did stock. Rides great and feels 100% safe. The coil overs replace your old shocks and springs so your bolts will be a thing of the past. Your coil over sets your ride height now. I'm still messing around with that to see where I want it.
Thanks again! Yeah I agree with you on the low but safe. Yer ride is so phreakin' bad azz btw.
Thanks,
- Eric
Old Oct 29, 2007 | 05:48 PM
Z28STYLE23's Avatar
Z28STYLE23
Thanks,
- Eric
Thanks Eric I appreciate that.
Old Oct 29, 2007 | 07:35 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
I don't think we have ever had anyone say any different. They are worth every penny.
Regards
Chip
__________________
..................Click for
Old Oct 29, 2007 | 08:24 PM
SS~7's Avatar
SS~7
These are my "to do" list! ... Awesome mod! ...
Old Oct 29, 2007 | 08:50 PM
IMXCITD's Avatar
IMXCITD
Great mod! Congrats!!!
Old Oct 29, 2007 | 08:57 PM
Higgs Boson's Avatar
Higgs Boson
I am running the Pfadts at 26.75 rear and 26 front with me sitting in the car. I have them on 10 front and 11 rear. I also had it aligned to my specs with me in the car. I also installed a C6Z rear sway (8mm bigger than C5Z). Oh yeah it turns real nice like.
Old Oct 29, 2007 | 09:11 PM
spiral04's Avatar
spiral04
Congrats Chris! The car looks awesome as usual. How does the ride feel compared to you old spring and shock set up? I know the new set up gives you ride height adjustability so you can drop 'er down low. Suspension is in my future, not near future though. Got to get a new clutch and some gears first.
Old Oct 29, 2007 | 09:24 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
where in Texas do you live? I'd love to feel the ride first hand if you live near Spring.
Old Oct 29, 2007 | 09:40 PM
DIXZ's Avatar
DIXZ
Gongrats Chris! I am glad you are so happy with the ride. The next time I see you I am going to hit you up for a ride!
Dick>
Old Oct 29, 2007 | 09:41 PM
Good review and your car looks great.
Old Oct 29, 2007 | 09:45 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
19/20s. Car rides better and smoother then my infiniti.
My stock Z06 rides better than my Infiniti...but then again my FX is lowered on 20's.
I gotta get a set of those Pfadts!
Old Oct 29, 2007 | 10:33 PM
Z28STYLE23's Avatar
Z28STYLE23
The old setup with the shocks and springs were good but when you go as low as i want it is too close to their exceeded limit of travel so they didnt work out so well for me. WIth the PFADTs I can go lower then I want an maintain same spring travel and adjust the ride stiffness. Right now I'm running 7F and 9R.
Dick>
No problem bud. Anytime.
Old Oct 29, 2007 | 10:43 PM
  #33
jmesox's Avatar
jmesox
I'm not a big fan of lowering the car, but your car is really nice. I really like the front end.
John
Old Oct 29, 2007 | 10:53 PM
  #34
bgreen83's Avatar
bgreen83
do you have different springs? or bushings or are those still stock?I'm really thinking about doing this this winter
Old Oct 29, 2007 | 11:00 PM
  #35
Higgs Boson
im in grapevine. if you're ever in the metroplex, let me know!
Old Oct 29, 2007 | 11:59 PM
  #36
Z28STYLE23's Avatar
Z28STYLE23
The coil overs replace your stock springs and shocks. So you remove your leaf springs and install the coil over assembly(shock and spring) into your existing shock location.
Old Oct 30, 2007 | 01:20 AM
  #37
eschmidt's Avatar
eschmidt
Thanks for the review - been thinking about those myself
