Can a flat be repaired?
Old Oct 29, 2007 | 09:14 PM
kentyk's Avatar
kentyk
8th Gear
Default Can a flat be repaired?
I have a 2000 convert and I ran over a nail. I took it to the local tire shop and they said that the Goodyear Eagle GS run flat tires are not repairable. They quoted me a price on a new tire, it was $500. A little steep!!
The nail is not in the sidewall it is in the middle of the tread. Will a regular tire patch work to fix the tire or was I being scammed?
KK
Old Oct 29, 2007 | 09:17 PM
Richard Nogen's Avatar
Richard Nogen
I may be wrong but Les Swab tires just repaired a flat for me a week ago.
Vega$Vette's Avatar
Vega$Vette
You can patch it if the hole is in the tread.
Old Oct 29, 2007 | 09:20 PM
noahdr's Avatar
noahdr
I'm sure you could patch it but they say once you patch a tire the speed rating doesn't mean anything anymore. If they're pretty new tires I would just go to wally world and get a repair kit and do it yourself. But dont take your car to the track until you replace your tire.
Old Oct 29, 2007 | 09:24 PM
CHUXDRM's Avatar
CHUXDRM
I had a front repaired (nail in tread portion), went to a GY store, they dismounted, patched on inside, remounted, never questioned that it shouldn't be done. That was 20,000 miles ago, not a probem since!
Old Oct 29, 2007 | 09:26 PM
OsoBear's Avatar
OsoBear
Local GY dealer fixed one for me. $35.00. Proper lifting of car, careful removal of tire, with no damage to sensor, patch does not leak. Have driven highway speeds (85 or so) for ten hours at a time. No problems. Be sure repair shop is RF savvy, not all are!
Old Oct 29, 2007 | 09:32 PM
jrprich's Avatar
jrprich
I have had Discount Tire do the same on GY RF and on my Michelin's
No problems at all.
Old Oct 29, 2007 | 09:39 PM
They can be repaired, but the shop needs to use the plug and patch method for the repair.
Old Oct 29, 2007 | 09:52 PM
maxvalley's Avatar
maxvalley
Had one of my Mich's patched for a nail 3 months ago, all is fine! Sounds like you need to find a new tire stealership.......
Old Oct 29, 2007 | 09:58 PM
TexasMadMan's Avatar
TexasMadMan
Even if you could not get the tire fixed, you need to find a new tire shop. $500 for that Goodyear RF is waaaaaay too high.
Old Oct 29, 2007 | 10:03 PM
R Devil's Avatar
R Devil
Sounds like the old "it can't be fixed but we just happen to have a brand new one that we'll let you have for a steal". Find another shop.
Old Oct 29, 2007 | 10:06 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Absolutely it can be repaired.
Old Oct 29, 2007 | 10:08 PM
BATM4N's Avatar
BATM4N
Old Oct 29, 2007 | 11:03 PM
Goldfisher's Avatar
Goldfisher
The speed rating is determined by a test where the tire is ran at speed for something like a hour or two. If you're just driving the car on the street it's not likely that you would be going 160 mph for that long. Someone please correct me if I'm wrong about this. I don't want to get anyone killed.
Old Oct 29, 2007 | 11:08 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Repaired yes! Plug and patch out the door $50.
Old Oct 29, 2007 | 11:35 PM
2 GRUMPY's Avatar
2 GRUMPY
Had mine patched 2 months ago and no issues.
Old Oct 30, 2007 | 12:13 AM
TomBoy's Avatar
TomBoy
If you saw my post at all about the nightmare with the bungie strap, my run flat took a puncture from of these creatures from hell. It punctured the rear tire outside area tread whipping out $2500 damage to my car in about 8 rotations. But my runflat was fixed. I went to a very high tech tire shop and they said if the puncture is in the tread on the runflat, it can be fixed. They do fix it a little different. Took the wheel off and plug it from the inside. It's holding air fine. Cost me $25.00. They did say my rating went down one. In other words, I should stay under the 160 mph rating to probably 120 mph with that tire. Just be really really glad it was just a nail that gave you a flat. There are other really bad things out there....
Laurie
To Can a flat be repaired?
Old Oct 30, 2007 | 12:24 AM
gator492001's Avatar
gator492001
Discount tire repaired mine just fine ,but they informed me that they only repair the runflats once per tire so if I get a nail in the same one later on ,it needed to be replaced
Old Oct 30, 2007 | 07:54 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
I had a nail dead center in the tread area, just put a regular plug in mine never had a problem with it. You can run the tire with a 1" hole in it so I don't see the problem with using a plug. I took the tire to a local Goodyear store and they said a run flat could not be repaired wanted to sell me a new tire.
Old Oct 30, 2007 | 08:33 AM
jacks996's Avatar
jacks996
Jacks996
Just don't use it on a track after
