[Z06] changing clutch, PP, flywheel
Old Nov 1, 2007 | 04:37 PM
e-hodges's Avatar
e-hodges
St. Jude Donor '06-'09
Default changing clutch, PP, flywheel
I have a gently used complete clutch from a 07 Z06 and was wondering if anyone knows of a step by step (with pictures preferred) on changing it out on my 01 Z.
Thanks in advance
Old Nov 1, 2007 | 06:46 PM
BonestockZ06's Avatar
BonestockZ06
PM me your email and I'll send you Dope's step by step clutch install with pics.. It's in Word Format..
Old Nov 1, 2007 | 06:55 PM
Yellow03ZO6's Avatar
Yellow03ZO6
I just did my clutch yesterday and used dopes install. He gives you plenty of info. It wasnt to bad of a job it took me about 11hrs to complete. I also saved myself $850.00 in labor that i was qouted. I posted some pics of it on myspace. here is the link myspace.com/badazzzo6 goodluck with your install.
Old Nov 1, 2007 | 08:00 PM
zulatr's Avatar
zulatr
please send me the doc to mikezohsix@yahoo.com
can this be done by a competent person on the garage floor without a lift?
thanks
mk
Old Nov 1, 2007 | 08:26 PM
e-hodges's Avatar
e-hodges
PM sent
BTW I have access to a lift, good tools and I also bought new trw bolts, an aligngment tool and bearing.
I also bought the LAST 5 gallon pail of gl100 gear lube from VR racing and will change the rear end lube at the same time.
I also want to change the clutch fluid but now Im undecided on what I should put back in. Dot3 Dot4 or syn???
Old Nov 1, 2007 | 08:32 PM
BonestockZ06
thanks
mk
Sent..
PM sent
Mail sent. With a lift, it should be a breeze.. Good luck with it..
Old Nov 1, 2007 | 08:40 PM
e-hodges's Avatar
e-hodges
Thanks for the link, I have recruited a former Mr Goodwrench (now a nerd like me) to help out and I have access to a lift so Im hoping for a quick change.
Someday I'll tell ya about the 3 month lifter/spring/rod change on my big block.....
So, what clutch did you put in? PP and flywheel??
Old Nov 2, 2007 | 07:38 AM
Yellow03ZO6
a spec stage 3, and a spec steel flywheel
Old Nov 2, 2007 | 08:12 AM
AlwaysInBoost's Avatar
AlwaysInBoost
With Dope or Cajundudes writeups, this is not a hard job if you have all the right tools and some patience. get the proper tool for removing the pilot bearing and also disconnecting the clutch hydrualic line.
while you are in there make sure you change out your slave cylinder, pilot bearing and look into some heat shielding from DEI for the hydrualic line going from the clutch master to the slave.
other things to look into are an extension line for the bleeder which makes future clutch fluid swaps a BREEZE. Also, search for the drill mod on the slave cylinder.
Old Nov 7, 2007 | 01:30 AM
fmfrm250's Avatar
fmfrm250
Would it be possible to get those clutch installation instructions? If so my email is: jamesgennock@hotmail.com. Thanks
Old Nov 7, 2007 | 07:50 PM
BaseballDude's Avatar
BaseballDude
I just did my clutch yesterday and used dopes install. I also saved myself $850.00 in labor that i was qouted.
Curious...was that a dealer quote or independent tranny shop? I'd like to know what the specs say for # hours for a competent GM mechanic to do this job? I review Dope's procedure (outstanding and clear, btw), and I've done clutch jobs before, but this one would be WAAAAAY out of my league.
-Dean
Old Nov 7, 2007 | 10:15 PM
Z06Fix's Avatar
Z06Fix
Yes can you please send the clutch directions to eric98lude@yahoo.com
Eric
Old Nov 8, 2007 | 12:44 AM
Yellow03ZO6
-Dean
a performance shop that is a sponsor on all of these boards. They claim the book says a 10hr job and their rate is $85.00 an hour. Do it yourself it is not hard at all. just take your time.
Old Nov 8, 2007 | 02:26 PM
BaseballDude
Yellow, it's not so much my mechanical skills but more so having access to the multiple jacks and an extra helper. And also investing in a hundred dollars worth of specialty tools. I'll keep that "10 hour job" reference handy and go from there. I'm looking at an '02 tomorrow with 19K on the ticker (one owner car) so I'm hoping the clutch doesn't have too much chatter associated with it (i.e. glaze build-up or weakened disc springs) so that I can get another 30K or so out of it. The car has factory rubber so I'm already looking at a grand to replace that.
Thanks again for the insight...very informative thread!
-Dean
Old Nov 8, 2007 | 06:50 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi e-hodges -
A couple of things that you will run into that are not clear in most of the write-ups that I have see are:
The pilot bearing - go to Harbor Freight and buy a blind bearing puller tool - $20 and worth every penny. Use it to remove the pilot bearing.
When you install the new pilot bearing (you were going to replace that $11 part that costs $900 in labor to get to, weren't you?) you install it with the beveled edge facing towards the REAR of the car.
I found it was much easier to remove the torque tube from the transmission and install the torque tube first - I supported the rear of the torque tube with a motorycycle tie-down strap while installing the trans/diff unit.
Buy yourself four 6" 10mm bolts and one 2.5" 10mm bolt to use as a guide for installing the torque tube - put the tube in place - put in the 6" bolts finger tight, then install the 2.5 inch one and draw the torque tube into place. Remove each of the long guide bolts and replace with the stock bolts one by one. Finish by removing the 2.5" bolt and then torque the torque tube bolts down.
This will save you some hassle in my very recent experience.
Good luck and best regards -
mqqn
Old Nov 8, 2007 | 07:43 PM
STEVE HOLM's Avatar
STEVE HOLM
PM sent
IF YOU BUY IT FROM GM IT WILL BE DOT 4. THAT IS WHAT I USE TOO.
Old Nov 8, 2007 | 08:01 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
I REEEEAAALLY need to change mine too... anyone in NW FL?
To changing clutch, PP, flywheel
Old Nov 11, 2007 | 01:12 PM
98Vette408's Avatar
98Vette408
Cruising
Could someone send me that document
rudysmith@embarqmail.com
Old Nov 11, 2007 | 05:46 PM
LT1driver's Avatar
LT1driver
someone post dopes clutch writeup in the sticky section for those of us who will need it in the future
Old Nov 11, 2007 | 06:11 PM
ssdeuce's Avatar
ssdeuce
I'd like it too please. nhendri03@hotmail.com
