Having car painted
Old Nov 3, 2007 | 02:03 PM
dmoore's Avatar
dmoore
Default Having car painted
I am having my 00 Coupe painted next week! Staying with the factory color but there are some nicks and scratches from normal driving that I want taken care of so the car looks new! How long does the painter usually need to keep the car and any suggestion on what to look for when he is done or suggestions on what I should tell the painter or questions I should ask him?
Old Nov 3, 2007 | 02:08 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
spend the extra $500 and have him take off every panel possible. Basically everything but the rockers and roof Paint lines suck
Old Nov 3, 2007 | 03:35 PM
WvCorvette's Avatar
WvCorvette
Old Nov 3, 2007 | 03:48 PM
Bigcountry7's Avatar
Bigcountry7
You shouldn't have this problem since it is getting proffesionally done, but check for imperfections in the clear coat.
Old Nov 3, 2007 | 03:54 PM
dwspas's Avatar
dwspas
Look for dirt in the clear coat, if there is any have them buff it out. Look for metalic drooping, sometimes the metalic will droop or run. Look for overspray in areas where you normally would not find paint (i.e, windows, moldings, wheel wells, inside doors, under the hood, etc.). If there is any have them remove it. In the day light stand back and look at the car over. If you see something odd ask what it is. Sometimes, depening on the painter and air pressure, the color my differ from one area to another. If its obvious have them fix it. Remember your paint job may be fine for you and someone else may think it's crapy. Your the judge, if you like it go with it doen't matter what others think. Your the boss.
Old Nov 3, 2007 | 06:16 PM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
I used to paint but it's been close to 15 years. I'm sure plenty has changed. Just a few things off the top of my head. Make sure it's a reputable shop. Ask for a tour, see what kind of downdraft/sidedraft paint booths they use, see what sort of air drying system they have. Good shops tend to be proud and will be happy to show off their state of the art equipment. Ask what brand of paint they'll be using. Research the paint brand they use online. Some are much more reputable then others. Ask to see some of the vehicles that have been overalled, or even look at some collision work, see how well they matched body panels on those. Look for orange peel in the paint. Make it very clear this is a corvette not a chevette and you'll be looking for an appropriate job not just the cheapest. Overall appearance and attitude of shop can give you a hint to what type of work they do.
Before you take your vette in consider cleaning it yourself very thoroughly. Even pressure wash the wheel wells and under the hood. Getting as much dirt off the car as possible will reduce the chances of any gettting in the paint job. You'd be amazed at the condition some people will drop off vehicles in to have paint work done.
Old Nov 3, 2007 | 06:44 PM
02MillenniumVette's Avatar
02MillenniumVette
Are you going to keep the factory orange peel!?
Old Nov 3, 2007 | 11:06 PM
C5naples's Avatar
C5naples
Ask him if he knows where the jacking points are on the C5 corvette. I don't know anything about automotive paint finishes but don't the bumpers require a special flexing agent or something because they are made of rubber and possibly the paint cracks when the bumper is flexed in any way. I would think he would need to keep the car two weeks to properly take the car apart, prep, paint, re -assemble the car and clean it
Old Nov 4, 2007 | 12:09 AM
De_Vette's Avatar
De_Vette
No way it should take two weeks to run a car through the shop, but sadly your probably right. Alot of shops have a tendancy to push off overall paint jobs to push through the collision work ahead of them. They are fast jobs and bring in more money in the end. Overalls tie up the paint booths for alot of time. If you don't care how long it takes it doesn't matter but if you need the car back I would ask them to commit to a timeline.
If there isn't any body work to be done I'd think the car could be stripped of any lights, license plate bracket, ect., wet sanded and washed down in one day. The next morning tape off the glass and get it in the booth at the first opening.
Speaking of wet sanding, I've heard HORROR stories of some hack shops using a scotch brite pad instead of sanding
There is no reason to lift the car and your right, flex additive for bumpers although probably wouldn't need to be mentioned.
Old Nov 4, 2007 | 12:16 AM
Good luck with the paint job. Hope the shop does a fantastic job for you.
Old Nov 4, 2007 | 12:24 AM
ValiantSailor's Avatar
ValiantSailor
Make sure you know what paint the guy is using and if it is equal too or better than what is there now. Is he doing the sills? How much is he charging? Also find out what he wants to mask off. SPecify how many coats of clear. They will almost always try to skimp someplace to save a buck.
Old Nov 4, 2007 | 12:28 AM
jrose7004's Avatar
jrose7004
How long he keeps it differs from painter to painter and if he's doing it on the side or works on it every day.
Old Nov 4, 2007 | 12:54 AM
C5naples's Avatar
C5naples
Which means they will be lifting the car for sure!
Old Nov 4, 2007 | 01:09 AM
BATM4N's Avatar
BATM4N
Old Nov 4, 2007 | 03:48 AM
lil vette's Avatar
lil vette
I've got my house painting supplies in the garage, I can paint it for you. I will need to buy a new brush first. (wanna do a good job)
Old Nov 4, 2007 | 06:27 AM
Junkman2008's Avatar
Junkman2008
Old Nov 4, 2007 | 11:31 AM
dmoore's Avatar
dmoore
That would work out great! My mother in law lives in West Palm Beach I could make a weekend of it! Get my car painted and visit my mother in law!
Thanks for the offer but I think I would rather go to the dentist and have several root canals done without pain medication!
To Having car painted
Old Nov 4, 2007 | 02:20 PM
mickey_7106's Avatar
mickey_7106
for how much are u gonna paint ur car for if u dont mind me asking?
Old Nov 4, 2007 | 07:47 PM
Marcs c5's Avatar
Marcs c5
I was wondering aswell
Old Nov 4, 2007 | 09:01 PM
dmoore's Avatar
dmoore
I got a quote over the phone for $6000 to $7000 and when I drop the car off we are going to sit down and discuss the car, what all needs to be done, and firm up the quote!
