[Z06] Custom air intake
Old Feb 5, 2008 | 12:18 AM
  #161
NatB's Avatar
NatB
Originally Posted by 03blackZ06
siliconeintakes.com best place with best prices by far. trust me i do my reasearch on prices. clamps are really cheap also and fast shipping. thats where all my stuff is from. thanks mike
Old Feb 5, 2008 | 04:55 PM
  #162
tvlance's Avatar
tvlance
Yes they seem to offer everything needed to attach the filter to the MAF then to the air bridge. They don't have a coupler that fits between the air bridge and TB though (close on diameters, but only 3" long when 5" is needed). The SLP one looks nice, but even on sale at $46.30, that seems expensive for a short rubber tube. The odd size needed to join air bridge and TB may force me into paying $40+ for one. Oh well.... Corvette Tax again!
Old Feb 5, 2008 | 05:08 PM
  #163
03blackZ06's Avatar
03blackZ06
a forum dealer had these on sale for 35 or so in the for sale section. thanks mike
Old Feb 5, 2008 | 06:45 PM
  #164
fastbluels6's Avatar
fastbluels6
St. Jude Donor '10
Originally Posted by DERJ
I finally got around to taking some pics of my custom setup (don't mind the dirty engine bay...)
After seeing a C6 K&N FIPK, I just ordered the 18" filter replacement and attached it to the air bridge with another coupler. It is huge (and costs a kit less than just about any kit out there.)
It runs great and appears to have much more air surface that a blackwing.
hey just a thought u sould cut a square out of the black plastic behind the filter so u get some more air from under the car. thats basically how my hurricane works in my car...
Old Feb 5, 2008 | 11:00 PM
  #165
ruffian's Avatar
ruffian
$12 as I recall for a 3.75 to 4" reducer from silicone intakes. One thing to note, it's only 3" long. I think the SLP one is longer.
bob
Old Feb 6, 2008 | 06:14 PM
  #166
patjza80's Avatar
patjza80
Where did you find that bridge in carbon fiber?
Old Feb 6, 2008 | 10:11 PM
  #167
ruffian's Avatar
ruffian
I've got the same bridge.
http://www.westcoastcorvette.com/p-3...ower-duct.aspx
Take note that the coupler for this particular carbon fiber bridge to TB is ideally a 3.75" to 4.00" unit - unless you want to run an evil reducer... once bitten twice shy.
bob
Old Feb 7, 2008 | 01:56 AM
  #168
tvlance's Avatar
tvlance
The diameter of the hole on my stock air bridge on the TB side is just a hair under 5 inches, and the TB opening OD is just a hair under 4 inches. I'm not able to find any couplers on the internet that are the right diameters with the correct length (about 5 inches), so I'll go with the WCC coupler for $40 or the SLP one for $46.30. I definitely want to give this homemade intake a try though.
Old Feb 7, 2008 | 01:12 PM
  #169
03blackZ06's Avatar
03blackZ06
http://forums.corvetteforum.com/show....php?t=1788291
coupler $39
Old Feb 7, 2008 | 01:34 PM
  #170
nextime's Avatar
nextime
Dont they sell them at Autozone for like $14.00 or are these a lot bigger?
Old Feb 7, 2008 | 02:50 PM
  #171
zeevette's Avatar
zeevette
I did the same thing about 4 years ago. I used a K&N "custom" filter that's conical shaped, and fits like a glove in the restricted space. About $45. RF1040 is the type #, if I remember correctly. I've since gone to a Vararam that I got cheap, and honestly, can't tell any difference.
Old Feb 7, 2008 | 06:57 PM
  #172
fastbluels6
St. Jude Donor '10
bob
Old Feb 13, 2008 | 12:33 PM
  #173
03blackZ06's Avatar
03blackZ06
great intake for the money
Old Feb 14, 2008 | 07:28 AM
  #174
thetastelingers's Avatar
thetastelingers
Just ordered my air filter from Amazon.
Thanks guys.
Found the 4" straight piece on amazon......I ordered the filter last night though...ugh...
But whoever orders the filter can also order the 4" straight.
http://www.amazon.com/K-N-08761-Blac.../dp/B000FGI2WC
Old Feb 19, 2008 | 03:16 PM
  #175
Gordy M's Avatar
Gordy M
Originally Posted by desant89
Anyone? Pros, and Cons about doing it this way as opposed to buying one? Looks great to me, but I want to make sure I am doing things properly. Thanks!
When looking at cold air intake systems you have to look at the application and use to find what would be best for you. If you have a stock engine with simple mods like headers and you are interested in drag racing then the Veraram is the way to go. When speeds are increasing over the 120 mph then air restrictions become more important. If you are running a LARGE cam and head combo or big cubes (400+) then the bottom breathers become a better choice.
When P&M started the C5R project they evaluated every means possible for air intake. The bottom breather was necessary for the 427 to make high end up and they continue for the C6R.
For road racing/HPDE/TT the bottom breather provides sufficient intake air in a turbulant environment (other cars blocking the steady inflo) because the ducts where the Veraram pick up is located is in a low airflow location.
Old Feb 19, 2008 | 03:26 PM
  #176
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
^ Or you could realize that the cold air screens in a Z06 or the massive front facia opening on a tigershark feeds air directly to the filter area.
Cold air is cold air... we're not dealing with pressureized air here.
Old Feb 26, 2008 | 11:01 AM
  #177
thetastelingers
I got mine installed last night.
I used a 3 3/4" silicone straight from siliconeintakes.com. I tried to use the 4" rubber pipe connector, but it looked too sloppy. The inside dim was 4.25", so I ordered the 3 3/4" silicone piece.
It fit snug on the intake, but turned out perfectly.
Just FYI.
To Custom air intake
Old May 20, 2008 | 11:45 AM
  #178
TrplBlk01's Avatar
TrplBlk01
Originally Posted by 02QSZ06
So, we need that small filter too?
Yes, you can get the from any Auto Parts store for just a couple bucks.
Old Aug 12, 2009 | 09:59 AM
  #179
SueTaing's Avatar
SueTaing
Would this filter and setup work in a C5 coupe?
Old Aug 12, 2009 | 07:38 PM
  #180
edaniel7's Avatar
edaniel7
feeds the air pump...yes
