Brake Fluid
Old Nov 5, 2007 | 02:27 PM
earnhardt3n88's Avatar
earnhardt3n88
Default Brake Fluid
How often do you change the brake fluid?I'm a new Corvette C5 owner and I didn"t know and thought I'd ask.Thanks!!
Old Nov 5, 2007 | 02:39 PM
TraceZ's Avatar
TraceZ
http://kalecoauto.com/index.php?main...&products_id=1
Cross drilled brake hoses will keep the fluid cooler and extend its life.
Old Nov 5, 2007 | 03:04 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Depending on how hard you use your car it can be 1-3 years or everytime you go to the track. I use a good Dot 4 fluid. ATE Super Type 200 which is Amber in color instead of blue which stains the plastics. I change once a year. You should at least do it every couple of years or now if it has never been done on your 99. Don
Old Nov 5, 2007 | 03:09 PM
earnhardt3n88
It hasn't been done at all to my knowledge.Thanks I'll get that done this weekend!
Old Nov 5, 2007 | 03:22 PM
hotwheels57's Avatar
hotwheels57
...wouldn't that be a little messy?
Old Nov 5, 2007 | 03:24 PM
Ishams00vette's Avatar
Ishams00vette
Every 30,000. That and power steering are suppose to be done at 30.
Old Nov 5, 2007 | 03:25 PM
jovette's Avatar
jovette
Yep, it gots ta be cross-drilled brake hoses, the regular drilled brake hoses tend to squeak..........
Bob CTS's Avatar
Bob CTS
I use Valvoline Syn Power, always check the color and clarity of the brake fluid that tells a bunch, the darker it is means it needs to be changed. As mentioned above every 2-3 years is suffice for normal driving.
Old Nov 5, 2007 | 03:59 PM
AU N EGL's Avatar
AU N EGL
forget the manual change the brake fluid at a minimum of yearly. Your brakes will thank you. Plus you stop better and quicker on fresh brake fluid.
Once your brake fluid gets old, you get use to the feel. When the fluid is changed to fresh you think, " Why didn't I do this sooner?"
To Brake Fluid
