Need some help
Old Nov 6, 2007 | 01:14 PM
GKrenn's Avatar
GKrenn
Default Need some help
Driving in to work today early. Everything was going fine until I had to dim my headlights. When I did to my suprise, no low beams. They had been working. Is this possibly a relay? If so, where is it loated. Is it in the fuse box by the battery. Anyone else had this happen?
Old Nov 6, 2007 | 04:47 PM
WetteVette's Avatar
WetteVette
Old Nov 6, 2007 | 05:02 PM
Plasticfan's Avatar
Plasticfan
Check fuses #8 & 10 in the underhood fuse box. If you have no power to those fuses, I'd check out the light switch. I believe the headlamp circuits ground to the splice pack just behind the headlamps. HTH
Old Nov 6, 2007 | 07:00 PM
GKrenn's Avatar
GKrenn
Thanks, I will give that a check. I've been going through the shop manual but not much help.
To Need some help
