Knocking Noise
Old Nov 7, 2007 | 11:18 PM
johnathanrn's Avatar
johnathanrn
Default Knocking Noise
Hey all.... Heres the problem... when i start my car in the morning (its cold out now and i havent heard this before when it was warmer out) i hear a knocking sound. I dont think its coming from the exhaust because like i said when the car warms up the sound goes away. When i accelerate the knocking sound is faster. Any ideas?
Old Nov 8, 2007 | 12:06 AM
Oldvetter's Avatar
Oldvetter
Sounds like piston slap, go to pistonslap.com
Old Nov 8, 2007 | 12:28 AM
johnathanrn
could it be caused from when i reset the settings on my hypertech III? I used the setting where it said i can use premiun 91 octane fuel... should i set this back to using regular fuel? Also i changed the thermnostat to 195... before it would hardly go over 190 now it goes over 210.... should I set the hypertech back to regular fuel and set the thermostat to the lower setting? thanks.
Old Nov 8, 2007 | 08:34 AM
VinnyT's Avatar
VinnyT
Are you running 91 in her? If not, you could be causing heavy detonation. Also morning knock = piston slap like Oldvetter said. It is normal, nothing to worry about. Why did you change the T-stat to 195? I think 195 is stock anyway. Using the Hypertech, you should use at least a 180. You want to go colder, not hotter. Some go as low as 165.
Old Nov 8, 2007 | 11:10 AM
Whiteonrice's Avatar
Whiteonrice
It's piston slap. It usually goes away after a couple of minutes, Very common on the C5s.
Rick
Old Nov 8, 2007 | 11:55 AM
johnathanrn
thanks guys... yes i am running 91 in her.... and i have the non-rfg option selected.... lol thank od its normal at least i dont have to brin git into the mechanic and have her away from me for a week lol. oh and btw i called hypertech and they gave me the base numbers for the shift points... if anyone wants to know just post back here
To Knocking Noise
