Dead
Old Nov 8, 2007 | 11:27 PM
BAblackvette's Avatar
BAblackvette
Default Dead
Hey I went to start my C5 up again after driving it 2 hours ago and its completely dead. Lights flash on brief second and then kaput. No power. Engine wont turn over, lights wont go on, nothin. Any ideas??
Old Nov 8, 2007 | 11:42 PM
WWK888's Avatar
WWK888
Start with the obvious, check your battery. They can go south without warning.
Old Nov 8, 2007 | 11:54 PM
Robertelarkin's Avatar
Robertelarkin
I had that problem last week................it was my "Ignition cylinder" It sounds like your problem is different though. But check out my thread. Do a search on "My car will not start..........Help"
Old Nov 9, 2007 | 12:35 AM
DeeGee's Avatar
DeeGee
I had the same problem and in my case it was the battery. A straight swap for an Optima Red Top and I was back on the road.
Mine was a year old and had done 8k miles when it died.
If your battery is the original AC Delco, I'd bet money thats the culprit.
BTW, if you fill out your profile members can offer advice specific to your car.
Old Nov 9, 2007 | 06:58 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Battery likely, fill in your profile and help comes faster.
Old Nov 9, 2007 | 07:02 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Had the same thing happen Monday. Better check that battery and FAST. My positive post came completeky out of the battery, leaked acid, and now that I got it cleaned up, I'm having HVAC issues. Probably unrelated to the acid as it wasn't there long enough to cause any real damage, but who knows.
Check that battery!
Old Nov 9, 2007 | 07:07 AM
Originally Posted by WWK888
Start withy the obvious, check your battery. They can go south without warning.
Hope it is that simple.
Old Nov 9, 2007 | 07:23 AM
vetter79's Avatar
vetter79
If you replace the batt (or for any reason requiring removal) it sure as he!! doesn't hurt the put the following mat under it!
http://www.dccarcare.com/battery.html
Cheap Ins. for potential "ACID" leaking probs.
Old Nov 9, 2007 | 10:47 PM
BAblackvette
thanks guys, now that I have it pushed back into the garage i will check it out first thing tomorrow
Old Nov 9, 2007 | 10:48 PM
RussNRach's Avatar
RussNRach
Good Luck!
Old Nov 9, 2007 | 10:57 PM
mcgilles's Avatar
mcgilles
wow, that's an amazing coincidence...I know the guy that runs that business. he's an important person in the community of the other car in my garage. neat! sounds like a cheap insurance policy to me. I may have to buy one of those.
Old Nov 9, 2007 | 10:58 PM
Jet-Jock's Avatar
Jet-Jock
It more than likely your battery. You'll need a new one. Probably about $80. for a AC-Delco Pro series if you want OEM similar.
Expect all kinds of codes to have been set because of this. If you swap out the battery be sure to clear the codes, that should reset all the warnings. Low power on the PCM makes it very upset! Hope you aren't affected by column lock, low voltage will cause it to show its ugly head unless you've had it bypassed or not affected by it.
Good luck. If you need help with the DTC ask I'll post up the steps.
To Dead
