Another battery question
Old Nov 9, 2007 | 09:20 PM
futuretech's Avatar
futuretech
Default Another battery question
Dead battery on my 02'. Battery one year old. I left my radar detector plugged in for two weeks to aux port. Duh.
Now when I put the charger on I get a flashing underhood light and a clicking near the front of the car.
What is the correct way to recharge the battery?
Old Nov 9, 2007 | 09:34 PM
zTrek's Avatar
zTrek
Deep discharging can be very hard on a battery such that it may not fully recover. If the battery has been sitting around for awhile in a discharged state, you may want to use a battery charger that includes a mode for desulfating before attempting to charge it. Otherwise, just run a trickle charge to it overnight. If you still have problems, you will need to have the battery load tested. Your battery shouldn't have gone bad because of a one-time discharge if it's only a year-old. But with batteries, you never know. Good luck.
Old Nov 9, 2007 | 09:37 PM
futuretech's Avatar
futuretech
I suspect it has only been dead a couple of days. What about the clicking? Can I just leave charger on or does it have to come out of the car?
Old Nov 9, 2007 | 09:43 PM
Missile's Avatar
Missile
I agree, do a trickle charge overnight if your charger supports it. A year is certainly on the short side, but I had something similar happen a couple of years ago. Batteries can be fickle, especially if your car isn't a daily driver and sees rare action in the winter months.
Is it a fast clicking, or a single click that you hear?
Edit: A flashing underhood light could signal a loose battery cable too, which would cause repeated clicks instead of a single click.
Old Nov 9, 2007 | 10:51 PM
futuretech's Avatar
futuretech
repeated clicks by front headlight and pulsating (flashing) underhood light.
Old Nov 9, 2007 | 11:53 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
First, you might disconnect the car from the battery, then charge it. Secondly, I know my '99 has a feature that kills power after 10 minutes, but I don't know if it applies to the accessory plug or not.
Old Nov 10, 2007 | 02:52 AM
DeeGee's Avatar
DeeGee
If its an AC Delco I'd change it on spec.
Once those things die they are unpredictable. Mine died a death without warning at 8k miles. Luckily I was stranded in my garage and not away from the house.
Also the older batteries were prone to leaking before they updated the post design, although the guys say the 06s were a better design. Leaking acid and Vettes dont mix.
At least you know why it died. It may recharge and be fine. On the other hand.......................
$150 for a leak free AGM battery may be a good investment IMHO. An Optima Yellow Top is a deep cycle battery, wont leak and can live with occasional discharges.
Old Nov 13, 2007 | 06:32 AM
timd38's Avatar
timd38
Standard SLI batteries are not made to be deeply discharged. An Optima Yellow Top will take that type of abuse becasue it was designed to take it. I have a Yellow Top in my car. You can't beat Spiral Cell Technology for power and life.
Old Nov 18, 2007 | 01:19 PM
futuretech's Avatar
futuretech
Thanks guys. Wish there was a forum for "life" problems where things could be solved so easily. Hehe
Old Nov 18, 2007 | 01:31 PM
steve8's Avatar
steve8
I'd try to charge it for a day or two.
To Another battery question
