Winter battery decision
Old Nov 10, 2007 | 03:26 AM
murtro's Avatar
murtro
2018 C7 of Year Finalist
Default Winter battery decision
I have read many threads on winterization, but am still not sure what to do given my specific situation.
I will be storing my C5 offsite for the winter in an unheated garage. Winter here gets to minus 30 for days/weeks. I will probably only get to check on it about once per month. Should I take the battery out and store it at home nice and warm or should I hook up a battery tender? Is there any disadvantage to using the cigarrette lighter adaptor for the batter tender?
Thanks in advance for the advice!
Old Nov 10, 2007 | 03:31 AM
DeeGee's Avatar
DeeGee
If its off the road and not going to be used I'd pull the battery and store it in a warmer place. Added security aswell. No ones going to move the car without the battery fitted without a flatbed.
The only reason I'd put it on a tender is if I planned to use the car occasionally.
Best of luck with the withdrawal symptoms.
Old Nov 10, 2007 | 03:35 AM
murtro's Avatar
murtro
Default winterize battery
Hi - nope, no intention on moving the car from now until the snow melts in the spring.
Very sad, I know.
Old Nov 10, 2007 | 08:14 AM
rws.1's Avatar
rws.1
A battery tender will work fine.
Canadian Ttire used to sell a battery blanket that would keep the battery warm if you are worried about it freezing.
Old Nov 10, 2007 | 08:30 AM
I'd probably go ahead and pull it. Won't hurt it to hook it to a battery tender. Hope the winter season goes by fast for you.
Old Nov 10, 2007 | 08:33 AM
jgmachine's Avatar
jgmachine
I purchased my 03Z new in 2003. I have the original battery and it is in perfect shape. Every winter I have used a battery tender hooked directly to the battery.
yaknow's Avatar
yaknow
Every year a simply disconnect the battery , reason to remove. If your worried about freezing, it time to change the battery.
Old Nov 10, 2007 | 08:28 PM
RonJ's Avatar
RonJ
If a battery freezes, it's because the battery is flat. As the battery weakens, the sulphuric acid in the electrolyte enters the plates leaving just water in the electrolyte. The more discharged the battery, the more likely it is too freeze. A fully charged battery will not freeze in any of our climates.
Moral of the story? Put a float charger on the battery for the winter and forget about it!!
RonJ ...
Old Nov 10, 2007 | 08:33 PM
WetteVette's Avatar
WetteVette
Pull it, keep it warm, and on a battery tender. You'll be ready to go when the time comes.
Old Nov 10, 2007 | 11:31 PM
Jims2001's Avatar
Jims2001
Do the same every year.
Old Nov 10, 2007 | 11:36 PM
Oldvetter's Avatar
Oldvetter
Use a battery tender, but don't use the cigarette adapter. My battery tender directions said the cigarette adapter was not for long term use.
Old Nov 11, 2007 | 01:06 PM
murtro's Avatar
murtro
Default Thanks
Thanks for all the replies - seems like people all do things differently, but all seem to work. The decision seems to be either pull it and put a tender on it, or keep it where it is and put a tender on it...
Regardless, I guess I'm going tender shopping today.
Still no snow - nice sunny day today, going to enjoy cruising...might be the last day this year!
Old Nov 11, 2007 | 06:05 PM
Cart99's Avatar
Cart99
Gets equally cold here, and I also store my vette (and other cars) off-site. Disconnecting the batteries and leaving them in the vehicles has worked well for me. Simply re-connect the battery in the spring and start it -- never have had a battery-related issue in 39 years of vehicle storage.
Battery tenders are good products to be sure, but I for one question the need during winter storage -- particularly if your vehicle is unattended for several months.
JMHO
Old Nov 11, 2007 | 07:02 PM
hotwheels57's Avatar
hotwheels57
I just read an article that said that a typical battery loses 50% of its total charge in as little as 12 days of storage/non-use in modern electronics laden vehicles.
Disconnecting the battery and not using a float maintenance charger will probably reduce that %, but using one will all but eliminate any loss in peak power and sulfating of the battery.
Old Nov 11, 2007 | 08:27 PM
Cart99's Avatar
Cart99
I don't dispute the value of a tender if the battery is connected -- without it, discharge in 2 weeks or so on a C5 is a given -- with the expected battery deterioration that you describe.
What I question, is the use of a tender during unattended storage, where a disconnected battery has proven to be an acceptable (perhaps preferrable) alternative. Without several years of experience on this subject, I wouldn't question the popular opinion on this forum.
What I am suggesting, is that if you are leaving your car completely unattended, a disconnected battery is equally effective. I also have peace of mind that an unmonitored tender problem -- although rare --will not be an issue. It can be argued that removing the battery and connecting to a tender is the better alternative -- but my experience has shown this to be an unnecceary process.
Just my .02 cents
Old Nov 12, 2007 | 12:53 PM
silverbullit99's Avatar
silverbullit99
Default Battery tender question
I see quite a few of you use that battery tender,, I was thinking of getting one ,, now that my car is in storage. How easy is it to connect it. Does any one have pics of what the wiring would look like ? .... Sorry don't mean to high jack the original post.. but it's on the same topic
Old Nov 12, 2007 | 01:01 PM
T VETTE's Avatar
T VETTE
Murtro........fill some of your profile out so we know a little about you.
I think either way works on a battery as long as you have a tender on it.
To Winter battery decision
Old Nov 12, 2007 | 01:37 PM
hotwheels57
There's a positive and a negative lead...either use the supplied alligator clips or use the supplied ring terminals for a permanent mount. Either way has a quick disconnect. Some prefer to use a cigarette lighter connection.
Check out BATTERY TENDER by DELTRAN CORPORATION on the internet. You can also check out CTEK, a more "high tech" float maintenance charger from Europe.
I mounted my BATTERY TENDER PLUS (1.25 amp) to a post on my lift and routed the lead beneath the car...
http://i114.photobucket.com/albums/n...6-27-07005.jpg
Old Nov 12, 2007 | 01:38 PM
aaavette's Avatar
aaavette
There is another current post about the "best" battery tenders, with pics.
Old Nov 12, 2007 | 06:32 PM
murtro's Avatar
murtro
Default parked
Thats it - my baby is parked until the snow is gone. Very sad day.
BTW the battery is in and unhooked, no Battery tender....we'll see how things go in the spring.
