Trunk Lid Inner Cover Fix??
Old Nov 12, 2007 | 06:51 PM
TexasMadMan's Avatar
TexasMadMan
Default Trunk Lid Inner Cover Fix??
From time to time I see a number of posts on how to secure the carpeted covers to the inside of the trunk.
Has anyone ever tried this stuff to see if it works?
https://www.mightyputty.com/spark/in...g=mpaisseag100
Old Nov 13, 2007 | 05:39 PM
TexasMadMan
Anyone there? Hello.
Old Nov 13, 2007 | 05:55 PM
Bill Vett's Avatar
Bill Vett
check this out.....
http://forums.corvetteforum.com/show...ight=trunk+lid
Old Nov 13, 2007 | 06:15 PM
WWK888's Avatar
WWK888
I used a heavy duty velcro from Radio Shack and it worked fine. If you use that magic putty it will bond forever and cause damage if you try and remove it.
Old Nov 13, 2007 | 06:19 PM
TexasMadMan
No, I haven't used it yet. I have tried the wide heavy duty velco from Lowes and the cover still drops down in warm weather.
BTW, thanks for the replies.
Old Nov 13, 2007 | 09:47 PM
Kevin Conway's Avatar
Kevin Conway
I drilled 4 holes in the inner trunk liner and fastened it to the trunk with the push in type holders. Worked great for me.
Old Nov 14, 2007 | 12:13 AM
az57chevy's Avatar
az57chevy
I added some extra Styrofoam and Velcro strips as i felt there were not enough spots holding it in place. No problems so far after 2 AZ summers.
Old Nov 14, 2007 | 03:26 AM
dieseldave56's Avatar
dieseldave56
Default Oh , you're talking about the Z06/ FRC trunk deck....
Couldn't figure out what you all were having trouble with at first. I use the GM double head push in retainers for my leather cover panel. They work the same as GM door panels. Make a 5/16 slot in the panel and a 5/16 hole ( 6 total) to the inside of the trunk deck. Push and it stays, no sagging. GM part # 20451401. They are no visible.
Old Nov 14, 2007 | 07:04 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Originally Posted by Bill Vett
See the second post (from DeeGee)
To Trunk Lid Inner Cover Fix??
