LS1 engines
Old Nov 13, 2007 | 08:13 AM
jimyz's Avatar
jimyz
Default LS1 engines
In the C4 forums, Someone made a comment as to the aluminum engines being "throw away engines". Either meaning no good for re-build or durability. How is the durability and longevity of the LS1?
Old Nov 13, 2007 | 08:22 AM
vettes4fun's Avatar
vettes4fun
The LS1 is twice the engine that the LT1 and the L98 was. Them guys are pissed becuase there still driving the C4 so they have to try to make the C5 look bad. The LS1 is a great motor for high milage.
Old Nov 13, 2007 | 08:25 AM
MisterC's Avatar
MisterC
You'll see lots of instances on this forum where the engine has gone 100k+ and just keeps on hummung.
Old Nov 13, 2007 | 08:35 AM
lil vette's Avatar
lil vette
I had 214,000 miles on my C4, 165,000 I put on.
Old Nov 13, 2007 | 08:58 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
The LS1 is one of GM's best motors. Light, great HP.
Old Nov 13, 2007 | 09:05 AM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
The LS1 is a GREAT motor!! I will take it any day over old my L71 and L88.
Old Nov 13, 2007 | 10:29 AM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
The Gen III V-8 put GM back on the map in 1997. The Gen IIs are a good motor, but durability and reliability were first priority for GM in the development of the Gen III.
FWIW, the Gen III block was designed to be strong yet light. The iron block version is the strongest block ever developed because of the design engineering of the aluminum block.
Old Nov 13, 2007 | 10:34 AM
ALVETTE00's Avatar
ALVETTE00
Not to mention that I met a guy who intentionally tried to blow it up. He was successful but it took a LOT. Eventually it let go around 9000 RPM!
Old Nov 13, 2007 | 10:38 AM
timemender's Avatar
timemender
The C5 (and C6) LS engines have 6 bolt mains. (The block extends below the crankshaft center line)
Old Nov 13, 2007 | 10:52 AM
INaband's Avatar
INaband
CI 7-8 Veteran
The old Vega engines were junk, not the LS1....
Old Nov 13, 2007 | 11:24 AM
TheDEfan's Avatar
TheDEfan
The old small block LT1 is a throw away motor IMO. Old technology. They are a little easier to work on though and parts are cheaper.
Old Nov 13, 2007 | 11:34 AM
Jeff_in_Atl's Avatar
Jeff_in_Atl
Does it make any sense for GM to switch to a "less" durable engine? I saw a special on TV about the development of the LS series engines. They really put everything into the design and development of that engine. When they were doing a model analysis of the engine they found that the firing order which was originally the same as the SBC caused a harmonic in the engine causing a vibration. So they changed the firing order to eliminate the vibration. The eliminate the Siamese ports which cause hot spots in the head causing preignition. Straightened the intake runners bla bla bla.
Old Nov 13, 2007 | 03:41 PM
dwestsr's Avatar
dwestsr
I think they were referring to the fact that the Aluminum block LS1 cannot be bored for rebuild. It can be honed ~.002 or so. Some have developed replacement sleeves. As to the engine's durability, I have had c4 and c5 and I'll take the LS1 anyday: power, smoothness, no leaks, and no stupid optispark!!
Old Nov 13, 2007 | 03:46 PM
93vetteguy's Avatar
93vetteguy
Have both C4 LT1 1993 and the C5 LS1 no comparison. Both are great engine, but the power the LS1 create and the potential to create more power....
Old Nov 13, 2007 | 04:44 PM
MUKAK's Avatar
MUKAK
doz c4ers
Old Nov 13, 2007 | 04:50 PM
1965imp's Avatar
1965imp
The LSx motors are the best GM has ever produced. How can anyone complain about 350HP and 30 mpg?
Old Nov 13, 2007 | 07:26 PM
bonnell's Avatar
bonnell
I had 166K miles on my L98 C4 when I sold it and it was running strong. If the LS1 is twice the motor I gues I am set for a while.
To LS1 engines
Old Nov 13, 2007 | 07:43 PM
GKrenn's Avatar
GKrenn
113k and still turning strong
Old Nov 13, 2007 | 08:01 PM
disney04's Avatar
disney04
My DD Driver is a 98 Z-28, It was the first year that GM put the LS1 engine in a Z-28. It now has 134K on the engine and it performs flawlessly. It has never caused me any problems I love the engine and I hope to get 200K or more out of it. Dave
Old Nov 13, 2007 | 08:03 PM
ETM's Avatar
ETM
Actually most of the C4 guys over there arnt like that.I have both {LT1} {LS6}and I do agree with you that its a great engine and also durable.
