Quick battery question
Old Nov 13, 2007 | 03:20 PM
c5streak's Avatar
c5streak
Default Quick battery question
I don't want to start the whole battery choice thing again,
I just have a simple question. Does anyone know when ACDelco went from leakers to non-leakers? Mine is date stamped Oct 2003. It's working fine now, just wondering if I need to worry about leaks.
Old Nov 13, 2007 | 03:22 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
All batteries can leak. To keep you self somewhat safe use an AGM battry.
TTT for your answer.
Old Nov 13, 2007 | 03:39 PM
my6thvette's Avatar
my6thvette
I think that you are ok with the battery you have. Your profile indicates that you have 2004 and it should have a top post battery. It was the side post batteries that tended to leak. The only way that I would use a side post battery would be if it was an AGM.
Old Nov 13, 2007 | 04:12 PM
c5streak's Avatar
c5streak
It is a side post, installed by previous owner before he shipped the car to me in Jan '04.
So are ALL side post Delcos possible leakers, or just earlier ones?
Old Nov 13, 2007 | 04:15 PM
DeeGee's Avatar
DeeGee
From what I read if its a top post design and that date you should be OK. I've just lost all confidence in the AC Delcos.
My early AC Delco leaked. My 02 design (on the road in 03) died. At least it wasnt a messy death.
The guarantee is to buy an AGM battery which wont leak.
$150 for a battery or $$$ for a fix.
Old Nov 13, 2007 | 05:20 PM
screw991le's Avatar
screw991le
I had mine replaced, under warranty with a Excide Mega-ton. Autobots roll out Oh wrong Megatron
To Quick battery question
