C5 door locks
Old Nov 14, 2007 | 05:11 PM
firebal's Avatar
firebal
8th Gear
Default C5 door locks
New to me C5, Drivers electric door lock will lock but not open.
I have now removed the door panel, removed the door lock and tested the lock itself. This was done by hooking it up to a battery and reversing the polarity. The lock seems to work OK.
There seems to be a control box (retangular black) that has some elecronics inside. Would this be the problem?
I am getting a clicking from it both ways.
thanks Richard
Old Nov 14, 2007 | 07:45 PM
JH's Avatar
JH
Yup, probably that black box that controls the function. Do a search on the site, there are some folks who can rebuild them; that will save you some seriouis $$$$. Very common problem.
Good luck!
Old Nov 14, 2007 | 08:12 PM
Oldvetter's Avatar
Oldvetter
C5s use digital logic to control items, you can't do normal "electrical" troubleshooting on them. Best thing is to get a Shop Manual. You also need to pull up your codes using your DIC (do a search for how) and post any codes here for help.
Old Nov 14, 2007 | 08:16 PM
Bakersfield's Avatar
Bakersfield
Here you go, a little write up I did a while back. PM me if you have any questions.
http://forums.corvetteforum.com/show...ht=bakersfield
To C5 door locks
