C5 Mirror HELP
Old Nov 14, 2007 | 05:40 PM
c5lovinlife's Avatar
c5lovinlife
1st Gear
Default C5 Mirror HELP
The spring on my left side mirror has popped off inside the mirror, is there any way i can repair this.
Old Nov 14, 2007 | 08:23 PM
Bakersfield's Avatar
Bakersfield
Yes, but it is a little hard. Do a search in this forum, I found it once because I had to fix mine..... twice. The hard part is compressing the spring and lock washer back down onto the shaft. Plus you have to splice your wiring back together to, but just be careful to match wire colors and you should be fine. Some guys just buy a new mirror and have it painted to match, but that was more than I wanted to spend. Good luck....
Old Nov 14, 2007 | 09:05 PM
4DRUSH's Avatar
4DRUSH
C5lovinlife where do you live?
To C5 Mirror HELP
