Ls6
Old Nov 15, 2007 | 10:38 PM
derty01's Avatar
derty01
Default Ls6
How hard would it be to install a LS6 into my 98 C5, considering buying one to replace my LS1 with high mileage. What exactly would I need or would I just be better off to take it somewhere?
Old Nov 16, 2007 | 01:40 PM
Tokuzumi's Avatar
Tokuzumi
As long as you use your current engine wiring harness, I think everything should bolt right in. May need to have your PCM reprogrammed.
Old Nov 16, 2007 | 02:04 PM
DefenderC5's Avatar
DefenderC5
With so many performance engines out there (with some costing less), why settle with just an LS6?
Old Nov 16, 2007 | 02:55 PM
army2000's Avatar
army2000
St. Jude Donor '11
Why would you replace your engine? You can practically rebuild your stock engine block beyond LS6 performance numbers.
Old Nov 16, 2007 | 02:59 PM
bgreen83's Avatar
bgreen83
I think It is mostly swapping and just reprograming your pcm. Its basically the same motor with some tweaks to fix the problems on the ls1.
Old Nov 16, 2007 | 03:23 PM
uracowman's Avatar
uracowman
couldn't of said it better myself.
To Ls6
