How do you remove end links???
Old Nov 20, 2007 | 11:29 PM
97C5driver's Avatar
97C5driver
Default How do you remove end links???
How do you get the nuts off of the endlinks? I notice that the nut and bolt spin together and I have no idea how to get it apart. I see that the bolt as that odd shaped hole in it but what tool do i need?
thanks.
Old Nov 21, 2007 | 12:21 AM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
That "odd shaped hole" is a hex socket and takes an allen wrench. Use the allen wrench to hold the bolt in place while loosening the nut with a wrench or socket.
Old Nov 21, 2007 | 01:09 AM
97C5driver's Avatar
97C5driver
ok cool. thanks. the z06 bar i have in my garage has some odd end link on it and its a pain in the @ss trying to get it off.
Old Nov 21, 2007 | 01:31 AM
Pizzano's Avatar
Pizzano
Thats because the ZO6 endlinks are all aluminum instead of the cheap plastic/rubber stock ones.
Old Nov 21, 2007 | 07:06 AM
taz03's Avatar
taz03
also on the nut end is two flat sides that you can get a open end wrench on.
Old Nov 21, 2007 | 08:39 AM
slayer6x6's Avatar
slayer6x6
Snap On makes a great tool for this...
http://image.snapon.com/international/pdf/lp5slim.pdf
http://buy1.snapon.com/catalog/item....group_ID=20219
Old Nov 21, 2007 | 11:12 AM
97C5driver's Avatar
97C5driver
I didn't think about using a vice grip. I'll try that out. I had a flat head screwdriver in the hole while using the wrench to try and loosen the nut but it wasn't happening.
Old Nov 21, 2007 | 11:21 AM
kas61's Avatar
kas61
When I replced mine I found the job to be easier with the tires removed.
Old Nov 21, 2007 | 11:39 AM
diyguy's Avatar
diyguy
If you have an air impact wrench, more often than not, you can just 'shoot' the nut off very quickly without having to do the allen key thing.
Will even see in directions on coil overs and other items similar, it says as an alternate means for nut removal is the use of an air gun.
Has worked for me 100% of the time. (shocks, ball joints, steering knuckle parts and the like)
Old Nov 21, 2007 | 11:45 AM
DefenderC5's Avatar
DefenderC5
I used an open wrench on one side and a socket with an allen attachment inserted into it. Went off/on just fine
To How do you remove end links???
