need help
Old Nov 22, 2007 | 08:02 AM
Munky's Avatar
Munky
Default need help
I just purchased a halltech intake from a fellow forum member, and going to install this morning, but have a ridiculous question. The airbridge does not have a hole for whatever sensor is plugged into the drivers side of the stock airbridge.... Can someone explain what i do with this????
Thanks so much.
Old Nov 22, 2007 | 08:31 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
That's the air intake temp sensor......just drill the new airbridge in the same spot and transfer the grommet etc. from your old one
Old Nov 22, 2007 | 08:36 AM
trickflow's Avatar
trickflow
That should do it.
I bought a K&N for mine off the forum. It was for the early C5 with the the hole. I just put in a grommet and plugged it. Works fine.
Old Nov 22, 2007 | 08:38 AM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
I AGREE...
Old Nov 22, 2007 | 08:41 AM
Munky's Avatar
Munky
Thanks. i read the instructions on the halltec site, and there is no mention of drilling. I am now wondering if i was sold the wrong one. The warhead filter opening seems to be too large compared to the maf. unless I put one of the ruber gaskets and clamp bands on it.... I am just confused and frustrated right now.. actually pissed if this is the wrong item.
Old Nov 22, 2007 | 10:27 AM
Munky's Avatar
Munky
ok, I am an idiot yes, i admit it. I drilled the hole, looked perfec, but it is unfortunately a hair too large. the gromet fit but is slightly loose. what is solution to tight the gromet to the airbridge. i don't want to think i just tossed my $ away, but I may have. could I use a high temp gasket maker, or some kind of wrap on the gromet to create a snugger fit? Sorry about the stupid question, but I can't believe I f'd up like this - ever so slightly.
Thanks.
Old Nov 22, 2007 | 10:31 AM
vetter79's Avatar
vetter79
Try a wee bit of Aquarium seal (silicone). Most hardware stores sell it in small tubes and is clear and stays pliable.
Just let it set up for a bit 1st.
To need help
