Tnt C5
Old Nov 22, 2007 | 02:23 PM
Gbali's Avatar
Gbali
Default Tnt C5
I have Dex Cool coolant in my 2000 vette. I have read many articles that it is not good to use it. I called to get a coolant flush and I asked what they use. I said the manual recommends Dex and he said it is not good as can cause more damage than good. He said I was better off using a multi purpose coolant. What are all of your thoughts?
Old Nov 22, 2007 | 02:25 PM
vetter79's Avatar
vetter79
Dex Cool
Old Nov 22, 2007 | 02:31 PM
hotwheels57's Avatar
hotwheels57
The old DEXCOOL is evil discussion arises from the dead again.
When DEXCOOL was first introduced, GM supplemented it with tablets for some reason. Those tablets and air being allowed into the cooling system caused problems...a thick sludge which often ended up causing blockage in the heater core.
This was most commonly reported in mid '90s vehicles like the LT1/LT4 Corvette and Impala SS with iron block/aluminum heads.
The tablets have since been eliminated. The orange extended life coolant from DEXCOOL or PRESTONE is the way to go. It's also better for the all aluminum components in your Corvette and the enviroment.
Old Nov 22, 2007 | 04:07 PM
bucwheat's Avatar
bucwheat
G OOD INFO ,THANKS.
Old Nov 22, 2007 | 06:50 PM
When I changed mine, I put Dex-Cool back in. Shop said the radiator looked great, so I have no reason to switch to another coolant.
Old Nov 22, 2007 | 07:30 PM
INaband's Avatar
INaband
CI 7-8 Veteran
Dex-cool here
Old Nov 22, 2007 | 08:06 PM
jrose7004's Avatar
jrose7004
I'd keep Dex-Cool in it.
Old Nov 22, 2007 | 09:52 PM
widewheel's Avatar
widewheel
Had mine flushed last spring and put Dex-cool back in. The old fluid looked good.
Old Nov 22, 2007 | 10:16 PM
FASTRICE's Avatar
FASTRICE
Dex-cool equals next best break through in fluids for cars since synthetic oils.
To Tnt C5
