No!!!! Car troubles
funny, I was going to post a thread for the exact same issue tonight! I think it may be the key chip, I had a similar problem with my old Z28, one morning had to tow it in....cost around $300 for a new ignition. Right now I am going to take both keys with me, just in case, but I also will check the positive battery cable since I messed with it when installing my vent lights. But I think my issue began before that. I can sometimes pull the key out, turn it 180 degrees, and it starts right up. Hopefully it is not the ignition itself, I really don't want to spend $300+ just for that.
Guess what, it did it again!
It wont start! Guess it wasnt the lose battery cable. I think im gonna get a new ignition switch with key. Hopefully its not something like theft deterant relay
also, if you get a new switch, maybe you can let us know how the installation went..?
thanks!
Wounded Warrior Escort '11
Your profile doesn't say if its an auto or manual, but either way, sounds more like your clutch switch or Park switch isn't adjusted right. If its a clutch, the switch may have become intermittent. If the security is causing it, the security light would be on.
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
This sounds good in theory, But why no codes?
If you think it is the key chip, I suggest you clean it and the keyhole with a professional product called "Houdini". A locksmith recommended it to me and told me to never use WD40 or other spray lubricant on keys or keyholes.
Good luck.
Good luck.
The battery can easily start going bad after a year. When you tie that in with the draw of power our cars have when parked, and the lack of daily use, then our buddy the battery becomes suspect.
Yeah, the only code im getting is for my ABS or Traction Control, cant remember what it was but ill post it when i get it again.
The weird thing is, when I went to start it last night it wouldnt work. Woke up this morning and it turned on no problems. This happened Friday night as well.
But it's an intermittent no start. If the battery had low voltage reading I would doubt if it would recharge enough to act normally after sitting. They can, but it's more suspect to be an "open" circuit. Another reason I'm thinking this way is No Codes? Why not a "Battery out of range"?
If the shift lever isn't in park, it won't start. I don't know about neutral on the A4's since I own a MM6. Someone else here can advise if it will start in neutral. I think it should. It could be that your switch there is having a problem or come loose. In the case of a MM6 tranny, the clutch switch can become out of adjustment which will prevent it from starting for safety reasons. The switch itself can also go bad, but mine never has...so far. If the chip in the key isn't making the proper connections with the iginition key contacts, then I would think you would see the security light. Again, it won't or shouldn't start. Another possibility is the starter itself or rather, the solenoid within the starter. Usually you would hear a click and no turnover, however, the solenoid can totally fail since its nothing more than a combination of an electromagnet and a high current switch.
How is the weather there? This didn't happen with the Vette, but it did happen with another GM car I had: In warm weather, the car would not start after having been driven in the heat. It acted like a completely dead battery, but the accesories were fine. After a few hours of cooling it would start right up. When the dealer said it was the fuel pump in the fuel tank I was very skeptical. But replacing the pump fixed the problem.
I would bet on the key! Pull key and wait about ten minutes, then try your other key. Theft deterrent has to reset.
Edit: You must wait the 10 min. and the key has to be pulled from the ignition or the other key will not work either.
^^^^ hope you like them Greg! Well just got a call back from the dealer. They said they couldnt find anything wrong with it. They put it on the dyno and got no codes..........which is what I told him. He said that the positive battery cable was lose, I call BS on that. If the cable was lose would it still read 13v? Anymore theories on what it could be. I think ill take it to 21st century muscle.
OGC5
it wasnt the lose cable guys. even after i tighten it wont start. then the next morning it starts up just fine.
Have you tried holding the key in the start position for a good long while? Replaced the battery and the cured the whole starting issue for me.
