Vert Wind noise
Old Nov 23, 2007 | 02:14 PM
zolman's Avatar
zolman
Default Vert Wind noise
Are there any adjustments to bring the top of the drivers side window closer to the rubber molding. They do not quite match up and I am getting wind noise.
Before I start tinkering around I wonder if someone could give me an idea where/if I can make adjustments to get a tighter seal. The window and rubber molding are both in good shape.
Old Nov 23, 2007 | 03:30 PM
gilbroyer's Avatar
gilbroyer
Default I have this same problem
I have this same problem, I would love to hear if their is an answer
Old Nov 23, 2007 | 04:43 PM
MrLeadFoot's Avatar
MrLeadFoot
I recently saw a post where someone pointed out a little screw on the underside of the door. If you loosen the screw, and push whatever it's holding towards to the outside of the door, it pushes the bottom of the window outwards. I would assume that would tilt the top of the window inwards. Never tried it myself, so you might want to search for the thread just to make sure I rememered it correctly.
Hope this helps. If so, please report your findings so that I know for the inevitable future.
Old Nov 23, 2007 | 05:01 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
John's got a good writeup in here. I need to do it to my passenger's side window this winter.
http://www.johndennington.com/
Old Nov 23, 2007 | 05:45 PM
HERK's Avatar
HERK
Thanks for the info.
To Vert Wind noise
