i tried to roll the passenger window down the other day and it doesnt work. i really dont know if it ever did as i sit on the drivers side with the a/c on most of the time. any ideas? the car is an `04 auto with 40k on it. i havent done anything to the car but change the oil and drive it everyday. thanks.
Thats a great thread and everything you ever thought you wanted to know is in there.
Surprisingly, if the module is on its way South, a good sharp rap on the door can unstick it. That may only be a temporary fix. The other simple thing to check before getting into replacement parts is the connector in the door hinge area. Open the rubber gaiter and clean up and reconnect the plug in there. Its well known for coming loose. Also make sure theres no chafing of the wires where it routes through the door and the pillar
