[Z06] c6 zo6 brakes
Old Nov 26, 2007 | 01:36 PM
dasilvaszo6's Avatar
dasilvaszo6
Default c6 zo6 brakes
Just need a little help.
I was selling my 01 zo6 brakes with bear eradispeed rotors when i was reading thru some posts... Question is will my 01 zo6 accept c6 zo6 calipers right on to my stock brackets? And also i have the 1" upsize on the rear, however i have 19/20 rim combo on the car now, which was ordered to accept the big brake conversion?
Old Nov 26, 2007 | 05:54 PM
dasilvaszo6
Default brakes
Does anyone know?
Old Nov 26, 2007 | 06:38 PM
on3r's Avatar
on3r
I have no idea, but I'd imagine the C6 Z06 calipers have different mounting points.
I highly doubt it'll be a direct swap over.
Old Nov 26, 2007 | 06:58 PM
AU N EGL's Avatar
AU N EGL
what off set do your wheels have? if it is not large enough the C6Z brakes may not fit your wheels either.
Old Nov 26, 2007 | 07:26 PM
VETFEVER's Avatar
VETFEVER
Frank, I am told the C6 Z06 is a direct bolt on. With your size wheels, diameter will not be a problem, but offset could be. Spacers will solve that if is a problem.....
Old Nov 26, 2007 | 07:42 PM
dasilvaszo6
Default brakes
The offsets should be ok as i ordered the wheels expecting to go big brakes, if i can just bolt them on i would be in great shape as my rotors are like new. My only concern would be if the rear 1" up rotors with the new calipers would be too big?
Old Nov 26, 2007 | 08:36 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
yes they bolt on to where your brackets bolt on. as long as your offset allows and you have 18"+ rims you should be good to go.
Old Nov 26, 2007 | 08:53 PM
JJ25's Avatar
JJ25
I have done the C6 Z06 brake upgrade and they bolt right up to the stock locations. Even used the same bolts. You will need longer SS brake lines though. Sounds like your squared away with wheel fitment.
Old Nov 26, 2007 | 09:40 PM
NightmareZ06's Avatar
NightmareZ06
I have the c6z brake kit on the way,,,N i ordered the goodridge c5 ss brake lines, are they not gonna be long enough, should i have ordered the c6 ones?
Old Nov 27, 2007 | 08:35 AM
JJ25's Avatar
JJ25
the goodridge lines are long enough. do they have square fittings for the calipers? if so, you'll have to grind off the fitting stop on the caliper.
Old Nov 27, 2007 | 03:16 PM
NITRO UK's Avatar
NITRO UK
the goodridge c5 lines fit but like has been said you can grind off some of the tab stop,brings the hose away from the top bolt.i had eradispeed
rotors but didnt bother to even go there to see how close the would have come.i used racing brake brake rotors.the six/four piston calipers
bolt staight up no problem
nitro uk
Old Nov 27, 2007 | 03:26 PM
The Red's Avatar
The Red
How did you like your eradispeeds? I'm considering a set for my '01. Why did you decide to go to the c6z brakes?
Old Nov 27, 2007 | 04:32 PM
dasilvaszo6
Default brakes
Really its just a look, i have i forged 19 front and 20 rear so i would like to fill the gap a little. They are great brakes! I have the 1" up on the rear hawk pads and ss lines and with the stock wheels it looks sick!I am willing to sell them only because i was going to buy the whole c6package from west coast corv.Thanks for all your help guy's if they don't sell then i wil just buy the calipers.
btw does anyone know how to post pics i would like to show you guy's them...
Old Nov 27, 2007 | 06:34 PM
NightmareZ06
Ohh thats cool,,thanks for the response....I just got the brakes today and im waiting for the lines to come in so i can put them on. I feel like a little kid when i get home, I run out front to see if theres a box in front of the door where are they!!!
NightmareZ06
[QUOTE=NITRO UK;1562925867]
WOW they look NAsty!!! great work
To c6 zo6 brakes
