Tire size question?
Old Nov 28, 2007 | 05:40 PM
jamestronix's Avatar
jamestronix
Default Tire size question?
Hi, would a 275/40/17 look ok an the front of a 2000 corvette with stock wheels or will it be too tall?
Old Nov 28, 2007 | 06:02 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
It's a little too much tire for the OEM 8.5" wide wheel. (width wise)
On a 9.5" wheel it would be fine, matched up to something like a 295/35x18 on a 10.5" wheel in the rear.
Old Nov 28, 2007 | 06:03 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Height is fine, and yes, that size works well on the front.
However, it is a bit wide for the stock 17x8.5" wheel size. The 275 usually calls for a minimum of 9" wide wheel. If you have 17x9.5" fronts, then yes, it's a good size to use.
Old Nov 28, 2007 | 06:10 PM
army2000's Avatar
army2000
St. Jude Donor '11
Remember 275's were mounted on your rear 18x9.5 wheels from the factory.
Old Nov 28, 2007 | 07:57 PM
jamestronix
They have 245/45/17s on them right now, how much wider is the 275/40/17? I think I have 8.5" wheels on the front.
Old Nov 28, 2007 | 07:59 PM
jamestronix
I have some almost new 275/40/17 tires from my 03 cobra and my wifes 2000 vette really needs some front tires and I don't want to spend any money on them because that is money that I could be spending on my 03 Z06, LOL!
Old Nov 28, 2007 | 09:09 PM
Glennm27's Avatar
Glennm27
How much wider? 275mm - 245mm = 30mm
30mm = 1 3/16"
IF you have the OEM rims, then yes they are 8.5"
To Tire size question?
