CD Changer Bracket Question
Old Nov 29, 2007 | 10:53 AM
Golf Man's Avatar
Golf Man
Default CD Changer Bracket Question
I'm installing a CD Changer and having problems locating the bracket that you pop rivet / glue to the car. (the one with the 2 - 10mm bolts attached)
I have checked with a couple of parts desks and they have nothing from GM.
If you have a parts number please forward it. If you fabricated your own, what did you use for material?
Any help would be appreciated.
Old Nov 29, 2007 | 10:55 AM
Patches's Avatar
Patches
Here's a thread I posted about my installation.
http://forums.corvetteforum.com/show....php?t=1740665
Old Nov 29, 2007 | 11:01 AM
stingray71's Avatar
stingray71
Do you already have the COR-HAR harness? If not, then you can buy them both here I think:
http://www.mnrelectronics.com/corcdchanink.html
If you already have the harness, you might be able to sell the extra one on the forum.
Old Nov 29, 2007 | 11:19 AM
LoneStarFRC's Avatar
LoneStarFRC
Try 10264812 (need two) and 3530297 for the nuts (need 4). BTW, everything's metric.
BTW, the screws that go through the mounting brackets and into the CD changer are 11503044 (need six) are also metric.
The pop-rivets and sealant you'll have to provide yourself.
HTH
Old Nov 29, 2007 | 06:26 PM
Patches's Avatar
Patches
I ordered the brackets from Gene's Karshop (vendor list bottom left) and found the Cor-har on ebay.
Old Nov 29, 2007 | 09:20 PM
fdxpilot's Avatar
fdxpilot
This is where I got my changer. While they have the whole package listed as one item, if you call the parts dept, they will probably be able to send you the mounting hardware.
http://temp.corvetteforum.net/c5/ken...rtspage6.shtml
BTW - Fichtner is a supporting Vendor/Dealer, and has been for many years.
Old Nov 29, 2007 | 09:41 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
To CD Changer Bracket Question
