130 oil pressure
Old Dec 4, 2007 | 08:04 PM
kurtis1973's Avatar
kurtis1973
Default 130 oil pressure
Hey guys anyone have any trouble with the oil pressure guage pegging out at he top and the digital says 129-130 psi the oil life has been up for a couple days Im wondering if I just need to reset that and it will go back to normal? There is no way I have 130psi oil pressure tho so something is wrong
Old Dec 4, 2007 | 08:06 PM
c5Cruiser's Avatar
c5Cruiser
From: Corona CA - "An Armed Society is a Polite Scociety"
Mine pegged. They do that when they go bad.
Old Dec 4, 2007 | 08:16 PM
Oldvetter's Avatar
Oldvetter
You need to replace your oil pressure sensor, do a search, plenty of great posts.
The way to check is to turn ignition on, with engine off, if it reads any pressure your sensor is bad. You should not have any oil pressure with engine not running.
You have 3 options: 1) pull intake manifold and replace. 2) Pull intake manifold and install a remote sensor setup (easy to change next time), 3) remove your windshield wiper panel and cut hole in body and replace.
Make sure your connector is clean of all oil and only torque to 15 ft-lbs. Multiple failures are common. Some say the NAPA part is better than GM's.
Old Dec 4, 2007 | 08:17 PM
kurtis1973's Avatar
kurtis1973
is the sensor easy to change? is the a online manual to show me exactly where it is , so i can change it?
Old Dec 4, 2007 | 08:18 PM
kurtis1973's Avatar
kurtis1973
Thanks for the info
Old Dec 4, 2007 | 08:20 PM
MY5THVET's Avatar
MY5THVET
Mine is pegged too. It's my next project. Here is a link to doing the job. It's under the intake, I am going to reroute it while I am in there.
http://forums.corvetteforum.com/show...ressure+sensor
Old Dec 4, 2007 | 08:27 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Either you guys are building your LS engines too "tight" or like oldvetter mentioned your OP sender is toast. Check out the sticky at the top of the "C5 Tech Forum" for options on the replacement procedure.
Old Dec 4, 2007 | 10:06 PM
berryj's Avatar
berryj
Here u go Kurtis. See my post #272 for details on this procedure plus a relocate. I had to do this 3 times over about a 1.5 yr period so please do this once and do it right the first time and make it easier for yourself in the future.
http://forums.corvetteforum.com/show...1588172&page=7
To 130 oil pressure
