Anyone ever check float voltage?
Old Dec 5, 2007 | 01:21 PM
bobby777's Avatar
bobby777
Default Anyone ever check float voltage?
In storage on float 100% charged--ever checked what the volts are with the maintainer unplugged? If so please let me know volts and brand of charger--thx.
Old Dec 5, 2007 | 06:07 PM
Oldvetter's Avatar
Oldvetter
Not sure what you are asking? Do you want to know the battery volts with battery tender unplugged? Initially it will be high, but if you keep it unplagged it will get lower.
Just checked my Vector Smart Maintainer (set on 1 amp), I got 12.65 volts. New Red Top Optima Battery.
If you hit it during a charge cycle it could be as high as 13.2 volts ( I have seen this).
Old Dec 6, 2007 | 08:49 AM
bobby777's Avatar
bobby777
12.65 is too low--should be 13.20-13,check it when the battery charger shows float mode after being in float for several hours--
Old Dec 6, 2007 | 11:10 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
My IOTA DLS 55 has a float charge voltage of 13.6 and a full charge voltage of 14.2
... oh and it goes with me
Old Dec 6, 2007 | 08:11 PM
Oldvetter's Avatar
Oldvetter
Bobby 777, Did you read closely what he wanted? He wanted the voltage with the battery maintainer UNPLUGGED from the 110 volt line but still connected to the battery!
To Anyone ever check float voltage?
