Well I am going to go with the Corvette Enhanchments they look wicked ! and just a quick question how do you remove the side light or reflectors whatever there called.
oh and is Richard of CE a member here ?
Richard's SN is C5vetteLS1
The side markers are removed with a 10mm deep socket AND standard depth from the holes of the outside tail lights. They're speed nuts and you'll need a deep socket to loosen them and the stadard size to finish it because of clearance....unless you have a 10mm open/box end wrench (that will take care of it all)
