[Z06] Knob question...
Old Dec 8, 2007 | 12:45 AM
CURL's Avatar
CURL
Default **** question...
Does anyone use the shift **** from UUC Motowerks?
I am new to the forum and I'm yet to see this in anyone's car pics...
I am thinking this **** on a C6 shifter is the way to go on my '02 '6.
Here''s a link: http://www.uucmotorwerks.com/RKC5/
I power shifted today and stripped my stock ****, so reluctantly (I have my eyes on a Callaway Honker) this'll have to be my first of many investments...
Any feeback? How does it fit and look coupled with the stock boot?
Old Dec 8, 2007 | 12:48 AM
VETTE-DUDE's Avatar
VETTE-DUDE
Looks sharp, but have not seen this style of **** for a vette. in person or on the forum....unique...
Old Dec 8, 2007 | 01:00 AM
CURL's Avatar
CURL
Hmmm...
I had one on my E36 M3 and it far surpassed any quality expectations, but I don't really know if I should trust a Euro tuner on an American muscle car. Ya know?
I need to do something soon though, I threw the **** in the trunk and I drove home shifting with the threads...
Old Dec 8, 2007 | 10:37 AM
jmc12's Avatar
jmc12
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
I saw a picture of one like it on one of our cars, I liked the stock one better it looked out of place if I can but my 2 cents worth in...
Old Dec 10, 2007 | 12:36 AM
striper's Avatar
striper
Very nice looking ****. I have a billet aluminum **** that I purchased a while ago from West Coast Corvettes. It has a nice shape and a Z06 logo engraved in it. It also is about half the price, but this other **** is real nice looking also. One thing you should be aware of with metal shift *****, they will be affected by ambient air temperatures coming through your windows. It's not too bad in the winter when the **** is cold, but in the summer time they can inflict burns when they are baking in the sun. Keep the **** covered when parked, or carry a glove or sock under the seat to put over it when the **** is HOT!
Old Dec 10, 2007 | 11:53 PM
ericstanley's Avatar
ericstanley
According to the website, it was "specifically designed for the 1997-2004 Corvette C5." If that's true, then it won't fit on a C6 shifter. You'll have to have the opening hogged out to fit the larger diameter shaft of the C6 shifter. You'll then need to drill and tap a small hole on the rear for a set-screw since the C6 shifter's shaft isn't threaded. I know this because I had a machine shop enlarge the opening on an MGW Pistol Grip shift **** to install on my C6 shifter. As others have said, you should carry something in the car to cover the shifter if you do this - it gets very hot.
Let us know if you decide to do this!
Old Dec 11, 2007 | 03:04 AM
dieseldave56's Avatar
dieseldave56
Default Just run a die on the C6..............
The C6 shifter arm diameter is .570, which perfect to run a 9/16-18 die down on ( C5 shifter uses a 9/16-18 thread). Your new **** will already have 9/16-18 thread ( C5 shift **** is 9/16-18 thread, go figure!)
I've threaded two of these C6 Z06 shifters in my C5s. Use a jam nut under the shift **** to lock in place. I doubt you'll see it. I believe there are a lot more 9/16-18 thread shift **** options in the market than the OEM C6.
Just a thought , if you want to keep the intergrity of the C6 shifter arm ( not thread it) just run a 9/16 drill bit into the threaded **** you have. Drill and tap a set screw to the base of the **** to align with the tapped hole in the C6 shifter arm.
Last edited by dieseldave56; Dec 13, 2007 at 05:58 PM. Reason: update or just late thought?
To Knob question...
