Car just died
Old Dec 8, 2007 | 08:04 PM
KeithG's Avatar
KeithG
Default Car just died
Went to get in the Vette (2002) yesterday to go to work. First thing I noticed was that the key fob did not make the lights come on as usual, car was already unlocked. I'm thinking I need a new battery for the fob, no big deal. Got in and tried to start the car and nothing, no gauges, no lights no starter drag, nothing, not a sound, totally dead. My wife took me to work.
She called AAA and they came out and charged the battery and it started right up. She took it to a near by Autozone and they ran a check on it and said the battery and alternator were fine. She brought it home a let it run for a half hour or so and then shut it off. This evening I go to get in it to go somewhere and the same thing all over again, key fob does nothing, cars dead, nothing at all. Whats up here? Thanks!!
I did a search and did not find what I have going on here, please help.
Old Dec 8, 2007 | 08:21 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
You need to have a load test done on your battery. Regardless of what the car parts place says, I'd bet you have a battery headed south.
Old Dec 8, 2007 | 08:46 PM
Bob CTS's Avatar
Bob CTS
Also check your connections.
Old Dec 8, 2007 | 08:55 PM
LEANDRO's Avatar
LEANDRO
I am voting for the battery
Old Dec 8, 2007 | 09:40 PM
DAS ZED's Avatar
DAS ZED
Old Dec 9, 2007 | 03:32 AM
DeeGee's Avatar
DeeGee
If AAA charged the battery during a quick visit all they would do would be give it enough charge to get the car started. You'd need a long drive or an overnight charge to put enough spark back into it.
Next question is how old is the battery. If its an OEM Delco, they are renowned for leaking. For peace of mind, now that its started showing its age I'd replace it on spec. Almost certain that would solve your problem.
If the cars a DD regular use should keep the battery topped up. If its a weekend car you might want to think about a battery tender as these cars always have a minor drain even when dormant.
If its any consolation I'm on my third battery on my 02.
Old Dec 9, 2007 | 07:11 AM
rws.1's Avatar
rws.1
I would think your battery has been sulphated from continuing discharging... get it load tested for free at Autozone.
If it is the battery,put a new gel or spiral cell type battery in it .
Old Dec 9, 2007 | 07:40 AM
VETTE47's Avatar
VETTE47
Bad Battery Cell.
Old Dec 9, 2007 | 08:48 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
If you still have the OEM battery then that is my guess.
Old Dec 9, 2007 | 08:49 AM
Sounds like you may have some component of the car that is not shutting down like it should and creating a steady drain on the battery. Either that or your battery is on its way out, but that should have shown up when AutoZone checked it the first time. Might have them recheck it.
Old Dec 9, 2007 | 08:53 AM
KeithG's Avatar
KeithG
Thanks guys
I was tinking it had to be a bad battery. The one in it now is not OEM. The car is a DD and the battery in it now is only a year old so I can get it replaced for no cost. I will look into the gel, spiral gel battires.
Old Dec 9, 2007 | 11:09 AM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Bummer! Like someone else said, double check your connections to ensure they are clean and tight. Both ends of your main ground. Could be that simple (hopefully)
Old Dec 9, 2007 | 02:48 PM
vettman96's Avatar
vettman96
If the battery is only a year old I believe that you have other
problems. Either a steady drain short in the system or possibly a
grounding issue.
Load test the battery before you replace it and that will be a good
indicator of where to start investigating.
If the battery is truely only a year old, you have another problem.
Good Luck
Old Dec 9, 2007 | 03:16 PM
jayindy's Avatar
jayindy
Keith,
I hope your fix is a battery.
(as a result of your thread, I've asked Santa for a battery tender)
Old Dec 9, 2007 | 03:34 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
I agree that unless your C5 is your daily driver you definitely need to keep a battery tender on it. My Redtop only lasted two years because I didn't have a battery tender at that time. Even the best of batteries can only stand about 100 deep cycle discharges and recharges and if your weekend driver sits there for two years only being driven on the weekends it will get those 100 cycles as our cars constantly draw considerable power from the battery. The amount they draw is small if the car is driven daily but if allowed to sit all week your battery will be down considerably and week after week of this routine will kill your high dollar battery.
I hook up my battery tender to my battery any time I don't intend to drive the car within the next day or two. It only takes a minute to do it.
Old Dec 9, 2007 | 03:59 PM
Phanni's Avatar
Phanni
Could be something like a under hood light not going off or and interior light.
Old Dec 9, 2007 | 04:48 PM
Vega$Vette's Avatar
Vega$Vette
Battery. Period.
Old Dec 10, 2007 | 11:34 PM
KeithG's Avatar
KeithG
Its ALIVE. Just wanted to let you guys know you all nailed it. The core of the battery went bad. Got a free replacement and all is good to go. Thanks guys
Old Dec 11, 2007 | 06:47 AM
Wicked Weasel
Usually the 2nd place I check (fuses would be the first)
To Car just died
