I'm doing the initial changeover to the K&N drop in filter and there is a seal that has to be installed. It looks like there is no way to install it without removing the whole induction box? What's the easiest way to remove it?
The oem C5/Z06 air filter assembly is attached to two pegs on the metal horizontal cross member beneath the front fascia. The assembly has two rubber grommets that secure to pegs, just like the two grommets/pegs on top of the radiator cover which secure the oem air bridge.
The easiest manner is to remove the entire assembly from the throttle body down to the air filter assembly. It's an easy DIY that you should familiarize yourself with anyway.
Loosen the worm clamp at the throttle body, release the air bridge from the two pegs on the radiator cover, remove the wire connector from the MAF (or air bridge, depending on year of vehicle) and wiggle the air filter assembly off the two pegs on the cross member. Install the K&N w/ seal and reverse the procedure.
You should use some lubricant on the four grommets/pegs which will make future R&R much easier. I prefer white lithium. Here is an image of my oem air filter assembly (slightly modified for more square inches of inlet air) showing the position of the rubber grommets...
Thanks for the help and your air filter assembly looks amazing. All I have is WD-40 so guess I'll wait for another day until I can pickup some of that white lithium.
Any lubricant will work, WD40 will be fine. Spit or WINDEX will work in the same manner. I just prefer something that lasts longer as does white lithium.
Can't get the darn wire connector loose....and I killed an outlet in the garage so no decent lighting. Guess this is going to wait for another day, any tips on getting that connector off?
Read CRC cleaner was good to, just spray some on and wipe off I guess? Only have 13K miles but figured while it is exposed might as well clean it, dealer tried to get me to spend $90 to have it cleaned and that was at 10K miles.
Regarding the connection at the MAF, the small white clip gets pulled out first...be careful it'll go flying. Then the connection can be pulled apart.
Just spray the MAF wires with specific MAF aerosol cleaner. Don't wipe the excess off the wires or they might be damaged.
Thanks, I've got a grey clip I took out but still wasn't budging. I'll see if there is another clip in addition to or maybe I just need to carefully wiggle it more. Was concerned about damaging it. I decided to wait for daylight to make it easier especially being the first time I've taken that stuff apart.
Got it installed over lunch, thanks for the tips. Daylight made all the difference too. Would have waited, but I had a rare free min with no smoke blowing from the neighbors house last night and tried it, worked through the smoke at lunch and got it put on.
Looks like it's running about 5 degrees hotter though, is that normal?
OK that's what I figured, don't recall every seeing the coolant above 195 but 200 isn't much difference, was a bit warm outside.
My throttle body was spotless from what I could see but didn't open the valve, I figured at 13K miles why mess with it. I'll do it myself when the time comes.
