[Z06] Windnoise? Normal?
Old Dec 12, 2007 | 04:41 PM
rwd's Avatar
rwd
The wind noise level varies from car to car. Generally, it's not bad. The usual source is the area around the B-pillar or the adjacent insulation.
There have been TSB's on the subject. One is below, but there are others, iirc, and I'm not sure there was ever a definitive fix, although it was a known issue. Individual installation and tolerances seem to have been involved, and sometimes the assembly plant's solutions were less than elegant.
Since that generation Z is no longer in production, many of its boards are turning into mod boards, so if you want information about the car itself, I'd suggest searching the archives.
http://www.corvetteactioncenter.com/...8Add+Sealer%29
Old Dec 12, 2007 | 06:24 PM
Hooker's Avatar
Hooker
I've got an '01 Z with 19k and no wind noise at all. (Now my '05 Burb ... that's a different story.)
Since I've added the padded partition and shoed it with Vredesteins it is a very pleasant, and relatively quiet, driver.
One thing to consider if looking to buy one with bad wind noise is if the door has been repaired or replaced it could be difficult to fit it perfectly. Consider the possibility.
Old Dec 12, 2007 | 07:08 PM
only59's Avatar
only59
I guess I just gotta ask..
are you guys with the excessive wind noise issue driving down here on the roads ? or are you up there with the 747's ?
Old Dec 15, 2007 | 02:22 PM
04_Z06_CE's Avatar
04_Z06_CE
Originally Posted by jmc12
Originally Posted by 04_Z06_CE
Sine you know tha proper name , do you know where I can find these ?
04-Z06-CE, I called our dealer they are in fact discontinued.. He said they are called R/S and L/S blow out clips and he give me two names of dealers that have them is stock according to his confuser (computer)..$ 32.12 each
# 1 Richard Hippard Chevy, Clermont CA. suppose to have two, phone # 909-624-4541..
# 2 Advantange Chevy, Bowling Brook Ill. suppose to have four, phone # 630-378-2300..
Also told me if you have no luck with these two get back to him and he will get a couple more names...Hope this helps you out JTM....
My dealer Sunset chevy 941-366-7800 talk to Mike in parts dept. Are if you like I will take care of it, let me know what happens...
Special thanks to you my freind...
I was able to pick up a clip from Richard Hibbard In Claremont, Ca...
I know that they a had a few and so did Advantage Chevy...
Its because of people like you that I admire really awesome people that do nothing but help others ...
Thanks!
