[Z06] Windnoise? Normal?
Old Dec 10, 2007 | 07:59 PM
hpfiend's Avatar
hpfiend
Default Windnoise? Normal?
Hey all,
The Z06 I drove over the weekend also had terrible wind noise with the windows up at around 65mph on the drivers side. I am sure it would be much worse the faster I went.
I don't think I noticed this in the other one- are they all stricken with this problem?
Thanks!
Andrew
Old Dec 10, 2007 | 08:04 PM
Big Kidd's Avatar
Big Kidd
You were hearing the road noise........coming from the tires. All factory Z06's are like this. There is no sound dampening material under the carpet. It's another item that adds to weight.
Old Dec 10, 2007 | 08:09 PM
redtopz's Avatar
redtopz
I have wind noise from my driver's side window and water leaks in too. I need to get it back to the dealership while its still under warranty.
Old Dec 10, 2007 | 08:26 PM
Bob CTS's Avatar
Bob CTS
oops you got two of these threads see the other for my reply.
Old Dec 10, 2007 | 09:03 PM
hpfiend's Avatar
hpfiend
Thanks! Yes window was up all the way I put it down and back up- and no this was definitely wind noise- I could hear the tires too.separate noise.
More to look forward to.
Old Dec 10, 2007 | 09:12 PM
froggy47's Avatar
froggy47
Originally Posted by hpfiend
Hey all,
Thanks!
Andrew
Mine's not bad. I would compare CLOSELY the fit of the window on yours with one that has no noise problem. There are adjustments & weather strip can tear.
Old Dec 10, 2007 | 09:15 PM
whtgt02vert's Avatar
whtgt02vert
i have a lot of wind noise in my z but thats only over 85. when i drove back this weekend from ruidoso i had a lot of wind noise, also a lot of drone. nothing some music cant cover up. i know that the cause is my weatherstripping
Old Dec 10, 2007 | 09:32 PM
apriliacati's Avatar
apriliacati
Is this the car with 7000 miles?
I get alot of road noise and it get worse with the windows closed.
Never noticed any wind noise.
How much is the guy asking for it?
Old Dec 11, 2007 | 09:17 AM
hpfiend's Avatar
hpfiend
No the windnoise car which I don't think I would want at most any pricepoint now is being offered for a non-negotiable 30,998 (CARMAX). The previous owner listed it for sale on here and locally for a long time with no luck so he traded it in at a lower price I know but will not disclose as he is a forum member and has been very helpful to me.
the 7,000 mile car was perfect and they were asking 37,980.00- I will buy a c6 before I touch that one... My dad picked up his 08 crystal red npp coupe yesterday and it is AWESOME!
Old Dec 11, 2007 | 11:53 AM
only59's Avatar
only59
How could you hear the WIND noise over the rear tires noise ?
Old Dec 11, 2007 | 11:54 AM
hpfiend's Avatar
hpfiend
It was so loud I thought the window was open! I heard the tires at lower speeds before the wind noise started...
Old Dec 11, 2007 | 12:09 PM
mark896's Avatar
mark896
My driver side window does the same thing. I guess there's an adjustment clip that I hear varying opinions on how to do it and if it's even worth it.
It's annoying as hell though.
Old Dec 11, 2007 | 12:23 PM
YellowZed's Avatar
YellowZed
Mine does it too - at 6000 miles. Sounds like it is from the back edge of the window rather than the top. Starts at around 60-65mph. I will try to adjust it out in the spring (which means May here in Minnesota!) - seals are in perfect condition so it is not that.
Old Dec 11, 2007 | 01:03 PM
1962 Fuelie's Avatar
1962 Fuelie
Lots of Tire to road noise, but no wind noise..... Thank heavens for the beautiful music from the exhaust!!!!
Old Dec 11, 2007 | 02:51 PM
JCENZ06's Avatar
JCENZ06
mine does this too, but my hard plastic clip that holds the window against the weather stripping is missing. Anyone know where to get one?
Old Dec 11, 2007 | 03:47 PM
Bracati's Avatar
Bracati
My 03 has the same wind noise on the driver side when I purchased the car with 16K a year ago. A couple months ago, I removed the inner panel and went through the various adjustments found in the manual. It is much better now, I never got water through the leading edge, but still hear the wind at free way speeds. I might end up replacing the rubber seal one of these days.
Old Dec 11, 2007 | 07:32 PM
Weapon X's Avatar
Weapon X
What year is it??
My 06 Z06 has to be reset if the battery is unhooked or if there is any noise. Put the windows all the way down and then run the window up to the top and hold for three seconds and then hold up for another three seconds and the window is recalibrated.
To Windnoise? Normal?
Old Dec 12, 2007 | 09:32 AM
jmc12's Avatar
jmc12
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Originally Posted by 04_Z06_CE
Sine you know tha proper name , do you know where I can find these ?
04-Z06-CE, I called our dealer they are in fact discontinued.. He said they are called R/S and L/S blow out clips and he give me two names of dealers that have them is stock according to his confuser (computer)..$ 32.12 each
# 1 Richard Hippard Chevy, Clermont CA. suppose to have two, phone # 909-624-4541..
# 2 Advantange Chevy, Bowling Brook Ill. suppose to have four, phone # 630-378-2300..
Also told me if you have no luck with these two get back to him and he will get a couple more names...Hope this helps you out JTM....
My dealer Sunset chevy 941-366-7800 talk to Mike in parts dept. Are if you like I will take care of it, let me know what happens...
Old Dec 12, 2007 | 12:26 PM
04_Z06_CE's Avatar
04_Z06_CE
What A nightmare guys.....
At 85+ The wind noise is just wrong on my car..!
Its almost like its coming from the directly behind my ears to my left side...
Iam still trying to figure this one out...
Old Dec 12, 2007 | 02:27 PM
cobrakraiger's Avatar
cobrakraiger
I just picked my car up about a week ago it has 8,000 miles on it now and there is NO wind noise at all at any speed. There is road noise but no wind noise. I would say something is off with that car.
