Remove Key And Wait 10 Seconds.....
Phase one, install K harness, phase two reprogram computer, phase three removing steering wheel and remove/replace plate with one that has no holes, reassembly, then remove the computer interface connector and re-pin two connectors. It's not a pretty sight.
Here's a pdf of the recall:
Recall Notice
Or you could go with a column lock bypass, the servo must be working to extract the pins then power is removed from it and a by-pass module is installed.
There is a good illustrated installation procedure at LS1.com.
HawnHog. Just as they say above. Try cleaning the contacts. Also do as I did and check the Ohms on the pellet.
Here are the values;
VATS key codes
To read the resistance of the key with a digital volt meter, set it on ohms mode and measure the resistance of the pellet on your key. The BCM is programmed for a specific resistance value. The BCM measures the voltage drop across the key pellet. If it is within +/-10%, then the car will start.
The 15 resistor codes are:
Key# Value (Ohms)
1 392
2 523
3 681
4 887
5 1130
6 1470
7 1870
8 2370
9 3010
10 3740
11 4750
12 6040
13 7500
14 9530
15 11800
Thanks.
Greg
Or you can spend a half hour installing the bypass module.
I'm not aware of any bypass module installation failing in the field.
There is no charge for this recall, print a copy of the notice and take it with you. It states this in case there is any issue with local service, otherwise contact GM at the number they provide and they will educate the dealer service.
There is rumors of a time period in 08 where they will no longer pay for the repairs. I cannot comment on that yet as I don't know the truth.
No. Those are just the resistors pellets. You'd need a lot of keys and then the security system will make you wait several minutes before you can try the next key. The owner will probably show up before you reach the correct key-pellet combination.
My dealer said that it was due to acomputer issue with a ground, and they need to clean the ground under the battery, and it was "very" difficut to do due to the location - BS. they charged me 250 to wire brush and sand a ground - had a litte corossion which was causing all kinds of electrical issues.
not sure if this is your issue or not, but thought I would share...
However, can someone PLEASE, PLEASE tell me if the date of 2/29/08 is really the end of the matter. Surely a safety product recall cannot expire? This date is actually contained in Special Policy #05081 dated Feb 8, 2006 and is not mentioned in recall #04006C of the same date. In that Special Policy it says ".......this Special Policy covers the condition described above until February 29, 2008 regardless of ownership. The repairs will be made at no charge to the customer......"
I asked Corvette UK to clarify the date two weeks ago. I have chased them twice and they are yet to respond!!
Many thanks for any guidance anyone can give me and the guys over here.
Rich,
Did you get my email? I think I answered all your question and hopfully steered you in the right direction.
DJ
To answer a few other queries found on this rant:
1) a dealer can not (not supposed to anyway) provide anyone with a duplicate key UNLESS you can prove ownership of the car for which the key is being made for. (I checked w/my dealer...)
2) re: the GM cut off repair date on the column lock issue. I have a letter from GM that states they will no logner be reponsible after 2/29/08. My local dealer confirms this as well as the west coast/pacific GM rep. Also note, they will not provide any preventative measures. The problem MUST exist prior to them doing anything and of cousre prior to the cutoff date.
You can wait till Feb. '08 and take your chances or you can buy the column lock bypass system and be done wih it. I am continualy amazed that GM does not buy the CLBS and install it for free.... Certainly it is a hell of a lot cheaper than any of their 3 "fixes". Could be an issue of "make ***" on their part. I see a class action suit in the making if GM refuses to warrant this safety issue.
My local dealer under the cloak of secretcy, darkness & underhanded in-house policy (don't ask, don't tell; just betwen the service writer/tech/me) is going to remove the "K" harness that was a GM fix and install the CLB system. Lucky me. I butter them up pretty good.
If you want to discuss this issue further with GM they have provided a toll free number: 1-800-6302438. If you are not happy with the answer you get you can call the NHSTA at 1-888-3274236 to file a complaint.
Happy hunting & good luck!
Either setting should give you some sort of reading.
Make sure the probes are only touching the metal 'staple'-looking pieces of the pellet, and not the key itself.
The meter is brand new. I had my wife hold the key(s)so I could touch the metal strip without it jumping in my hand. Both her key and mine did the same thing - readings all over the place! I'm going to take it to our local (gasp) dealership to see what they think. The only reason I care is last nite got that "wait 10 seconds..." with my key in the ign. The rest of the evening is was OK. Just trying to be cautious. But these readings give me pause???
Sorry I posted that info in another thread, here:
If you are getting a msg stating "SERVICE COLUMN LOCK" or "PULL KEY AND WAIT 10
SECONDS", shut the car off and once again pull fuse #25 and leave it unplugged for 10
minutes. Reinstall it and all error messages should be cleared and should not return.
In regards to your DVM questions:
Usually you have two probes a red one and a black one which should plug into the DVM where the black probe plugs into the Common port and the red into the V or Ω (Ohms) port. You should have settings one for AC and one for DC ensure your is set to DC.
Next you'll probably have a setting for mA, V, and Ω (Ohms), set your to Ω.
You will have value settings for the type of voltage or amperage or ohms your reading. Depending on what your measuring you set it to that scale. If you don't select the right scale all that will happen is the value will have the decimal place in a different position. So instead of 1.4 you might see .14 or 14. depends on what you have set. Either way if your looking for 1.4 and you get .12 that means your just under the value your looking for.
Now with the DVM on and the probe not touching you should see 1 with the settings from above that is DC and Ohms.
Now put the two probes together and it should go to 0 quickly.
Set your scale to 20k.
Have your wife hole the key while you touch the probes one to each side of the metal of the chip in the key. For example I did it without any assistance and I get .52
Use that value to identify the correct resister from the list above.
Now with the power turned on the DVM and the probes not touching you should see 1 on the display.
As far as which probe where just determines whether you see a positive value on the display or a negative value, for example if I have the probes one way I get .52 if I swap them I get -.52.
It is very difficult to do without someone (or a vice) to hold the key while you hold the probes firmly against the pellet.
