Spark Plugs...........
Old Dec 11, 2007 | 03:42 PM
todbusa's Avatar
todbusa
Default Spark Plugs...........
Have a 97 vette w/mods,lots of mods. What spark plugs should I be running? NGK.....etc. What are the best of the best? All help will be appreciated.......thanks
Old Dec 12, 2007 | 08:21 AM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
AC Delco 41-985 will serve you well. if your budget allows a good set of performance wires. beware of bargin wires.
Old Dec 12, 2007 | 08:24 AM
bucwheat's Avatar
bucwheat
Old Dec 12, 2007 | 01:38 PM
ALVETTE00's Avatar
ALVETTE00
Yes, Delco 41-985 Iridium plugs are great.
You'll need an extenstion and swivel socket to remove. Apply some anti-sieze on the new plug threads. Make sure to use a torque wrench to tighten them to spec.
Old Dec 12, 2007 | 02:13 PM
todbusa's Avatar
todbusa
Car has MSD wires on. Just looking for the best spark plugs to run in it........thanks
Old Dec 12, 2007 | 02:17 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Need a better run down on mods on your Vette as the NGK work great on modded Vettes
Old Dec 12, 2007 | 05:59 PM
todbusa's Avatar
todbusa
Default Mods..........
Hear is a little run down of my mods, 64cc heads cam .585int,.585ext,112lobe, adjustable rockers,(all patriot performance) LS7 lifters LS6int,water pump,kooks headers,b&bext,dyno at 420rwhp 395rwtq just asking what other people are running for a spark plugs?
Old Dec 22, 2007 | 09:45 AM
todbusa's Avatar
todbusa
ttt...........
Old Dec 22, 2007 | 09:54 AM
DeeGee's Avatar
DeeGee
I went with NGK55s
To Spark Plugs...........
