[Z06] traction control!!!!
Old Dec 14, 2007 | 09:02 PM
03Z06GUY's Avatar
03Z06GUY
Default traction control!!!!
Can someone PLEASE explain the differences between traction control on, TC off, and Competitive mode?? Thank you!
Old Dec 14, 2007 | 09:10 PM
jrwood's Avatar
jrwood
I would like to know this also.
Old Dec 14, 2007 | 09:56 PM
pit-man's Avatar
pit-man
Simply put....
TC on keeps you from spinning the wheels very much and will keep you from getting sideways.
TC off will let you do what ever...
Competitive Mode will let you wheel spin but still keep you from getting sideways. Great for drag racing.
Old Dec 15, 2007 | 12:08 AM
ETM's Avatar
ETM
Competitive Driving Mode will take off your traction control but keep your Active Handling on.
When you simply shut down the the TC you have nothing.No AH no TC your on your own.
Old Dec 15, 2007 | 07:55 AM
jmc12's Avatar
jmc12
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Be sure you know how to handle this car if you take the TC off !!! You can get in trouble in a hurry...As you know these cars are fast real fast.. Competitive mode is the way to go....
Old Dec 15, 2007 | 10:29 AM
JustinZook's Avatar
JustinZook
TC on enables TC and active handling... comp mode turns off TC but still enables Active handling.... unless im running someone strait on ill leave TC on... took it off one time and around a turn got really squirly and did a 360... no bueno
Old Dec 15, 2007 | 11:47 AM
03Z06GUY's Avatar
03Z06GUY
Ok, thank you very much!!
Old Dec 15, 2007 | 12:20 PM
03z06BLK's Avatar
03z06BLK
do all vette have Competitive mode i think all i have is on and off for the t/c thanks
Old Dec 15, 2007 | 12:40 PM
spdislife's Avatar
spdislife
Comp mode will also allow the car to yaw further in turns before it takes over
Old Dec 15, 2007 | 06:06 PM
03z06BLK's Avatar
03z06BLK
Old Dec 15, 2007 | 07:34 PM
spdislife's Avatar
spdislife
hold the AH button down and in about 5 seconds it will switch to Comp mode...you'll see it on the DIC
Old Dec 15, 2007 | 09:23 PM
RonVette2's Avatar
RonVette2
In the competition mode are you able to slide sideways, sorta like drifting a little and still ride with it before the AH ingages?
Old Dec 15, 2007 | 09:33 PM
Bob CTS's Avatar
Bob CTS
Old Dec 15, 2007 | 11:29 PM
03z06BLK's Avatar
03z06BLK
Thanks spdislife
Old Dec 16, 2007 | 03:04 AM
Torqaholic's Avatar
Torqaholic
Veteran: Coast Guard
St. Jude Donor '09
I daily drive using AH. I have only seen it kick in 2, maybe 3 times. It allows me to side slip my normal "under control" amount (I don't "drift") without interfering but when I take emergency corrective action (cutting the throttle and steering into the skid) it helps me recover faster than without it. Slows you down a lot in the process.
My emergency reflexes have already been implimented before it "assists". AH is a very smart system. It seems to be proportional in strength and length of application to what is required. It has not kicked in when I didn't want it to.
Old Dec 16, 2007 | 07:52 AM
spdislife's Avatar
spdislife
When the car oversteers, the system is less intrusive since T/C is off. I'll notice the dashlight coming on, yet not have that same "shutdown feeling" you get when T/C is on.
Anyway, to answer your question, I'm not sure about drifting, but during oversteer with the nose of the car still planted, yes.
Old Dec 16, 2007 | 10:51 AM
RonVette2's Avatar
RonVette2
Just to clarify things, I wasn't trying to say that I wanted to or have been doing drifting, just maybe an occassional turning a corner and letting the rear end slide while accelerating to much and making the turn in a "in control" manner while sliding, in competition mode. Thanks for the responses.
To traction control!!!!
