Hey everyone. It seems that during idle, my coolant temperature rises up and above 200 degrees after a few minutes of idling, it's a slow and gradual increase.
Here's what i've done so far to see about preventing this (assuming that this is an issue):
- Flushed existing coolant using waterhose and blasts of air, refilled coolant with DexCool coolant and water mixture (50/50).
Anyone want to educate me as far as the temperature is supposed to be or what....i'm abit at a loss here and looking to you guys for answers.
If sitting at idle my Z will reach around 230, until the fans come on, and then will start to decrease. When you turn the air cond. on the cooling fans will come right away. You can have the fan on temp reprogramed , so your fans will turn on sooner.
Another go thing is to check the radiator for road debris, which will block air flow.
Your coolant temp is normal from what you are describing, a big factor is the ambient temp. In stop and go traffic in 80 degree weather, my coolant temps would get up to 225 or 230 until the second fan would kick on and bring them back down to 220 or so. The engine was designed to run that way.
You can check in between the ac condensor (sits in front of your radiator) and radiator to make sure there is not a lot of debris stuck up there. These cars act like vaccum cleaners since they sit so low to the ground they suck up a lot.
Hey Charlie, that almost sounds like a normal situation. If you are sitting still with the engine idling, there's no airflow through the rad, eventually you will reach around 230'F when the cooling fans will kick in and pull the temp down.
That is normal. They were made to run at that temp and like it that way. but least you have clean coilant and radiator If you want you can put a 160 tstat in and get it tuned to turn your fans on earlier to help it run cooler little longer. but 220 is not abnormal.
You can try cleaning any debris from the radiator air inlet area. C5s are great vacuum cleaners.
Rick
I cleaned out the radiator and condenser, Installed a 180 thermostat (this only droped the temp to 190) The bigest help came when I had it tuned and had the fans start at a lower temp I think around 195 for the 1st fan. Prior to this temps were always 196-98 and 215-230 in summer traffic here in Calif. Adjusting the fans is the way to go, and the 180 thermostat helped out some. Now in the worst summer traffic it runs 200-205
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
The cooling fan set temps above are for model years 2001 through 2004 C5s. The set temps for earlier model years (1997 through 2000) are somewhat different (the set temps being a little lower) and CharlieB's profile shows his car to be a 2000. However, the coolant temps that CharlieB says he is seeing at idle still appear to be well within the normal range for his model year.
Anyone wanting the factory set temps for the earlier model year C5s can either search the Forum or check the shop manual (try the Engine Section under Cooling System Description and Operation) specific to their car's model year.
That is normal. They were made to run at that temp and like it that way. but least you have clean coolant and radiator ................ but 220 is not abnormal.
Thank you everyone for your help! I see that this may be normal. Yes, I have a 2000 Corvette. I want to add that I am in New York and the average temperature these days is around 40 degrees. I'm by no means in any warm weather area.
If I sit in idle, the car will steadily raise up to 200 degrees...then 203....then 205...at that point, I shut the car. While i'm driving, the car stays at a consistant 190/192 degrees. This normal as well?
Why worry? Engine damage doesn't occur until 280*F + or so, so why worry?
As everyone says don't worry
I used to drive in Vegas and the fans would regularly cut in at 230 in stop go driving. Once they do the temperatures come straight back down. You'll probably do more harm by turning on and off than by letting the fans do the work. I suspect that you'll be pushed to get as warm as 230 in 40 degress OAT.
