dimming lights
Old Dec 29, 2007 | 04:55 AM
RedRckC5's Avatar
RedRckC5
Default dimming lights
Had AAA changed my battery during Thanksgiving since they were the only one that is open. Now, when I was driving my brother from the airport x-mas eve, I noticed that my lights seems to dim evertime I use my signals and during higway speed, it seems to dim when I hit a bump.
Now, should I check the connection or could it be a bad battery?
Old Dec 29, 2007 | 05:37 AM
DeeGee's Avatar
DeeGee
Fisrst step would be to reseat the power and ground connections. A loose lead would cause that.
Old Dec 29, 2007 | 08:34 AM
rws.1's Avatar
rws.1
It could be bad connection to the battery or to the alternator.
check you connections and then drive to a local Autozone. they will do a free curbside charging system test.
Old Dec 29, 2007 | 09:21 AM
Oldvetter's Avatar
Oldvetter
Check your battery connections, you should not be able to twist them by hand. If they need tighthened, only use 11 ft-lbs, especially if it is a sidepost regular (not AGM) battery, Over torquing is the #1 cause of battery leaking and your computer is under your battery.
Old Dec 29, 2007 | 10:03 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
This could help alot too
http://forums.corvetteforum.com/show....php?t=1667484
I did the Big 3 mod when i put in my stereo and it took car of my dimming light issues.
To dimming lights
