SS inserts
Old Dec 29, 2007 | 09:55 AM
granpastoy's Avatar
granpastoy
Default SS inserts
I am getting ready to install stainless steel insert and would like to hear some tips on the installation. Want the best looking job possible. Thanks in advance guys.
Old Dec 29, 2007 | 10:03 AM
jrose7004's Avatar
jrose7004
Clean the area with denatured alcohol, use tweesers and take your time.
Old Dec 29, 2007 | 10:05 AM
Illini82's Avatar
Illini82
St. Jude Donor '07
Most people will just tell you to prep according to the directions. I did this, and had my "R" fall off within 30 days. I complained to SS and they sent me a new one after telling me it was 100% my lack of prep. I had a local guy who had put 3+ sets on his vettes come over to help me out, same result pretty much except this time only half fell off. To this day my "R" is clinging to life but hasn't moved in months. If it does eventually fall off I plan on going somewhere else.
Good Luck! Make sure you prep perfectly.
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Cleaning the area is the most important part of this process!
Take your time and place them right as I have seen lots of vettes with misaligned lettering.
Good luck
John
Old Dec 29, 2007 | 10:09 AM
10U 99's Avatar
10U 99
you cannot get the mounting surface too clean! denatured alcohol, then adhesion promoter. surface temp minimum 65-70. press firmly and don't get in a hurry.
csexton's Avatar
csexton
I haven't had any problems with them staying on
Chuck
Old Dec 29, 2007 | 10:12 AM
luvmy82's Avatar
luvmy82
St. Jude Donor '12
To ensure a rock hard adhesion, and advice from the forum, I used waterproof epoxy. Peel off adhesive does not guarantee a permanent hold. Epoxy does. I also aided the prep by putting a very small piece of light grit sandpaper on the end of a pencil eraser to texture the surface.
Combined with a poor prep and a few car washes, those real expensive letters stuck on with sticky tape adhesive can fall off quickly. HTH
Old Dec 29, 2007 | 10:17 AM
jmorr649's Avatar
jmorr649
Great tips...I have some on the way, so I will be taking all of this advice. I like the idea of the sand paper on the pencil eraser trick. Did you get your waterproof stuff at Lowe's or more like Autozone kinda place?
Old Dec 29, 2007 | 10:19 AM
luvmy82's Avatar
luvmy82
St. Jude Donor '12
Any hardware store carries waterproof epoxy.
Old Dec 29, 2007 | 10:38 AM
0JPM@AutoBuffs
Former Vendor
That would be great if you never want to take them off!
Old Dec 29, 2007 | 10:40 AM
luvmy82's Avatar
luvmy82
St. Jude Donor '12
Duh...no kidding. The other alternative would be to buy them and run the risk of letting them fall off because the adhesive is semi-permanent?
Old Dec 29, 2007 | 10:41 AM
granpastoy's Avatar
granpastoy
Thanks a million for all the good tips. Happy and prosperous New Year to all.
Old Dec 29, 2007 | 10:47 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Are you installing them on the front or the back - or both? The other thing to remember is to make sure that you utilize the adhesive promoter that they provide with the letters. It will help the adhesive adhere better.
If you are installing the letters in the front - you need to slightly bend the "V" because it hits rights at the bend on the cover. In the back, I would strongly recommend that you dry fit the letters first. Good luck!
Old Dec 29, 2007 | 11:59 AM
granpastoy's Avatar
granpastoy
I am doing rear only. We have front plates (ugh) in Missouri.
Old Dec 29, 2007 | 03:45 PM
CHUXDRM's Avatar
CHUXDRM
Would weatherstrip adhesive be better than what they send with the letters, or as good as epoxy mentioned above? I have a set of ss inserts ready to go on next spring, want to make sure they stay on, could never get the cheap ones to stay on!
I bought a tube of weatherstrip adhesive to finally get my hood seal to stay on, now don't know when I'll use the rest of the tube.
Old Dec 29, 2007 | 04:43 PM
moserbe's Avatar
moserbe
Back at ya!
To SS inserts
