Shifter pix?
Old Jan 2, 2008 | 10:24 AM
jmorr649's Avatar
jmorr649
Default Shifter pix?
Anyone got some pix of shifter upgrades? I have the ol factory job on there and am thinking it needs a new look. So looking for something neat...
Thanks!
Old Jan 2, 2008 | 10:45 AM
INTRUBL's Avatar
INTRUBL
B&M short shifter with Vette Essentails boot.
Old Jan 2, 2008 | 11:01 AM
jmorr649's Avatar
jmorr649
[QUOTE=INTRUBL;1563430709]B&M short shifter with Vette Essentails boot.
Nice!
Old Jan 2, 2008 | 11:02 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
C6-Z06 Shifter I really like it.
Old Jan 2, 2008 | 11:10 AM
jmorr649's Avatar
jmorr649
[QUOTE=Capthuff;1563430924]C6-Z06 Shifter I really like it.QUOTE]
That looks really nice too...did you just change the head out? If that is called the head..not sure. Or did you swap out the whole thing?
Old Jan 2, 2008 | 11:18 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
I changed the whole shifter assembly. It cost less then $200 and took less then 1 hour to do. I got it from Gene Culley (forum Vendor). He usually has a group purchase/special going on.
I used the original boot, but cut it down a little bit. The shifter **** fits the palm of my hand perfectly. I am not a racer so, as far as performance is concerned, there are probably better shifters available. For my money and driving stlye, it is perfect.
Old Jan 2, 2008 | 11:21 AM
Tx Ray-C5's Avatar
Tx Ray-C5
that looks just like mine !!
Old Jan 2, 2008 | 11:27 AM
JJ 86's Avatar
JJ 86
Here's my C6Z shifter
Old Jan 2, 2008 | 05:04 PM
bbentley40's Avatar
bbentley40
Here is my C6Z06.. I love it.. and the price is nice too (thanks again to Gene Culley)!
As for the boot.. I cut it down a little.. and put a thick rubber band on my shifter (wrapping it over many times so it is tight but still able to pull each loop out a little to move it).. then put the boot on.. put on shift ****.. then turn the boot inside out over the shifter and slide the rubber band up over it. This is a little tricky since you dont wanna break the rubber band but you want it tight enough to hold the boot.
Old Jan 2, 2008 | 05:24 PM
IM28702's Avatar
IM28702
My big problem with the factory shifter was it's altitude... Just too tall. So, since the thing has like 3" of threads, I took a hack saw and cut off the top 1 1/2" or 2", and found a shift **** that sits down on the shaft more. I love it. And other than the ****, which I had anyway, it was free!!
Sorry for the poor pic, it was taken for the radio bezel (not finished) and not for the shifter, but you can still see how much shorter it is.
Old Jan 2, 2008 | 05:46 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I love mine. The old shifter feels like a truck shifter compared the the new ones
Old Jan 2, 2008 | 05:47 PM
jacks996's Avatar
jacks996
Jacks996
Instead of a rubber band I used a zip tie on mine
Old Jan 2, 2008 | 06:14 PM
Dave68's Avatar
Dave68
Here's my BPP short-throw shifter, uncovered. It's handle assembly is 16-way adjustable for the perfect fit, no matter how long/short your arms are and how wide/narrow your shoulders. It joins the Hurst, Ripper, and a couple of others as having the shortest throws out there.
However, to some, the short lever arm make shifting into and out of gears a bit tough - no problem - just add two .05 thick copper washers to the shifter detent that resides in the tranny case and viola, you have super-short throws AND ease of shifting - the best of both worlds!
Anyway, here're some pics of the shifter and ***** that I've used:
Old Jan 2, 2008 | 07:12 PM
Wah's Avatar
Wah
Old Jan 2, 2008 | 08:27 PM
leowiz's Avatar
leowiz
Originally Posted by Wah
This one looks quite elegant.
Old Jan 2, 2008 | 08:31 PM
ChiliPepperGarage's Avatar
ChiliPepperGarage
Dave68: That first photo is very "Terminator-esque"!
Here is my Hurst. I didn't like it at first but after putting on about 1000 miles I got quite used to it and like it very much now.
Old Jan 2, 2008 | 08:39 PM
ericstanley's Avatar
ericstanley
C6Z shifter w/ MGW Pistol Grip
To Shifter pix?
Old Jan 2, 2008 | 08:49 PM
Paulg680's Avatar
Paulg680
CI 7-8-9 & 12 Veteran
Wounded Warrior Escort '11
NOthing too radical here... I cut down my stock shifter and added the large black shifter **** with the white shift pattern. It works great, looks good and didn't cost very much.
Old Jan 2, 2008 | 09:15 PM
Dave68's Avatar
Dave68
The Hurst is very similar in feel to my BPP and I rowed the BPP for quite a while before reading of the anti-venom mod. Curious as to how different a couple of washers could make a shifter feel, I decided to try it out when the car was in the air for its annual oil change. Side-to-side shifting is unchanged, but dang, the 1-2, 2-3 and 3-4 shifts are much easier now, not quite as easy as the C6 Z06 shifter throws, but appreciably shorter. This is why I stayed with the BPP.
Old Jan 2, 2008 | 09:18 PM
C_O_R_V_E_T_T_E's Avatar
C_O_R_V_E_T_T_E
Hurst Shifter with kirban ****... nice feel, this one is chrome, but they have black and white also. i like the white with black shift pattern... omg the dust in the picture makes me sick! its been cleaned! i need to take another picture...
