Battery Issues
Old Jan 2, 2008 | 01:41 PM
jnfigueroa's Avatar
jnfigueroa
Default Battery Issues
Lately when I start the car all my gauges seem to reset on the HUD and on the DIC. My MPG resets, along with other bits of info.
Could my battery be going out? I checked the battery voltage when I'm driving and it reads approx 14-14.2
Old Jan 2, 2008 | 01:42 PM
hotwheels57's Avatar
hotwheels57
You probably need to check your battery with a load test.
Old Jan 2, 2008 | 01:51 PM
JH's Avatar
JH
Load test good idea, but short term, just turn the ignition to the ON position (not the Acccessories position) but don't start the car. Give the gauge a little time to read accurately and what shows is the level of volts your battery stands at. If less than about 10.5 volts on the gauge, a load test may tell you a new battery is in order.
Old Jan 2, 2008 | 01:56 PM
DeeGee's Avatar
DeeGee
I'd say its almost certain the battery is on its last legs. Classic symptoms
Remember the DIC voltage is only accurate when the car is running. Check with a multi meter across the terminals
Old Jan 2, 2008 | 02:02 PM
JH's Avatar
JH
Remember the gauge reading when the key is ON and the car isn't running is the battery's charge read out. When the car is running, it's the alternator charging level that's reading out.
Old Jan 2, 2008 | 02:07 PM
Oldvetter's Avatar
Oldvetter
Been there, when cranking voltage falls below about 8.5 volts, it erases these memories. You can try charging the battery. I load tested mine, my 800 CCA tested at 250 CCA and was bad.
I only use AGM batteries in my C5, since the computer is under the battery. Optima, Sears Platinum, Excide are AGM, be prpared to spend over $150.
Old Jan 2, 2008 | 02:20 PM
T VETTE's Avatar
T VETTE
How old is the battery??
Now days a battery is almost more important than the engine.
Old Jan 2, 2008 | 04:04 PM
GrayC5's Avatar
GrayC5
DeeGee is correct. The car's voltmeter was mainly designed to measure the output voltage of the alternator when the engine is running. There will be a certain amount of voltage drop from the battery to the voltage meter when the engine is turned off and you cannot get an accurate reading as to the battery's state of charge using the car's voltmeter. In order to get an accurate reading of the battery's state of charge, you will need to take a voltage reading directly at the battery terminals using an accurate digital volt-ohm meter (DVOM). Too, this will only tell you the battery's state of charge. One will also need to do a load test to fully check out the condition of the battery. The following link contains more info on the proper way to test a battery:
CAR AND DEEP CYCLE BATTERY FAQ 7.1
HTH
Old Jan 2, 2008 | 06:37 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
You need Handheld voltmeter from an autoparts store or even a wal mart. Measure the voltage across the battery. It should be between 11.5-12.5 volts. Anything below 11.5 is suspect and below 11 means you need a new battery now.
....or you could get your local auto parts store to check it for you.
Old Jan 2, 2008 | 08:18 PM
I'd have to say it sure sounds like a battery going bad. Might want to get it checked soon.
Old Jan 2, 2008 | 08:42 PM
Bob CTS's Avatar
Bob CTS
and most places will check it for free.
Old Jan 2, 2008 | 10:17 PM
Bills03Coupe's Avatar
Bills03Coupe
The settings on my HUD changed right before my Exide Orbital Died. Your battery need to be replaced.
Old Jan 2, 2008 | 10:52 PM
ValiantSailor's Avatar
ValiantSailor
Check your terminals for corrosian before you jump to any conclusions.
Old Jan 2, 2008 | 11:36 PM
moserbe's Avatar
moserbe
Time for a new battery IMHO.
Old Jan 2, 2008 | 11:44 PM
jo8243's Avatar
jo8243
Check all the battery/alternator wires, too. Mine had fried and pulled loose from the alternator. I had all sorts of elecrical gremlins until I finally realized what happened after the wire came all the way loose.
Old Jan 3, 2008 | 01:37 PM
jnfigueroa's Avatar
jnfigueroa
Thanks for all the info. Time to do some serious checking.
To Battery Issues
