Headlight Lift
Old Jan 4, 2008 | 09:20 AM
borkg2006's Avatar
borkg2006
Default Headlight Lift
I changed out my low-beam lamps with HELLA HB4 Xenon Blues (really can't see much difference from the bulbs I took out). In doing this I must have messed up the gearing on the drivers side headlight lift. It goes up fine but when I turn the lights off, it goes down and continues to grind for about 5-10 seconds after the light assembly is completely down - then the motor stops. I've tried manually raising and lowering it both partially and entirely to no avail. Any ideas???
Old Jan 4, 2008 | 09:23 AM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Your gears are toast!
You will have to replace them and I suggest the brass gears that I just put on yesterday!
Common problem !
Old Jan 4, 2008 | 09:43 AM
DeeGee's Avatar
DeeGee
Take a look at this thread posts 2 and 29. That gives a good run down on replacing the gear. Also Leaftye's sticky has agood summary in the C5 General sticky.
http://forums.corvetteforum.com/show....php?t=1817090
To Headlight Lift
