3...2...1....A4, GO! (A quick question)
Old Jan 6, 2008 | 04:14 AM
  #41
DeeGee's Avatar
DeeGee
Originally Posted by Mr. Couture
It seems as if you bought an automatic and are now regretting it. Possibly because you don't know how to drive stick, idk? Point blank, if you keep on down shifting you're going to fry a gear. So unless you want to keep on doing this I suggest you get a ratchet shifter. For the mean time, just keep it in over-drive and let the car do the shifting. Don't say I didn't tell you so
If that was for me Brian the answer is "sort of"
I went to buy an MN6 coupe and came away with an A4 Vert. Glad I did because I've had way more fun from the softtop than I would have had from the MN6.
Even so, I'll admit that having always driven stick (over 30 cars and this is only my second auto), the fact that my high performance sports car is an Auto is something of an embarrasment. Even my Ford Explorer in vegas was a stick
Back to the discussion though, if it sounds like I drive around pumping away at my A4 gears its not true. Most of the time it sits happily in D. My argument is that occasionally, road conditions dictate that a manual change is smart driving.
I've posted a thread in tech to ask whether ther transmission experts see any evidence of worse reliability through occasional use of the A4 in lower gears.
At this point I bow out gracefully
Old Jan 6, 2008 | 09:11 AM
  #42
Higgs Boson's Avatar
Higgs Boson
Drag racers (like myself) use automatics for consistency. However, they also have manual valve bodies in their transmissions so they have to upshift. However, they (I) also use air shifters to shift the shifter for them. It's all in the name of consistency.
A street car does not have a manual valve body or an air shifter.
A ratchet shifter won't do anything on a street transmission except make sure you don't go from 1-3 (which wouldn't matter anyways since the trans is still only going to go into 2.....
Old Jan 6, 2008 | 09:54 AM
  #43
garagpet's Avatar
garagpet
Around here, we have a lot of curvy mountain roads which are fun if you like to drive briskly. I'll lock it in 2nd gear to keep it from upshifting when I get off the throttle to slow for turns. That would mean that it would need to downshift as I exit the turn, and that's very annoying. Now, I don't drive it at or near the redline like this, as it'll do 55 in 1st and 100 in 2nd at the shift points (2.73 ratio). This method doesn't provide the best performance, as you never get into 1st, but it's fun and it eliminates all that shifting that you don't need or want.
Old Jan 6, 2008 | 10:12 AM
  #44
C5Wolfe's Avatar
C5Wolfe
Hey,
The real deal is to put it in "R" if you want a real performance boost! The "R" stands for Race as any gearhead knows. Thats would be my sugestion anyway!
problem solver Dave
Old Jan 6, 2008 | 05:00 PM
  #45
Junkman2008's Avatar
Junkman2008
Originally Posted by DeeGee
...Back to the discussion though, if it sounds like I drive around pumping away at my A4 gears its not true. Most of the time it sits happily in D. My argument is that occasionally, road conditions dictate that a manual change is smart driving...
EXACTLY! This is driving 101. Especially when dealing with extreme hills and down grades. This is when you want to work with the engine/transmission instead of having it searching for the correct gear. Choosing a gear manually in this situation will be to your and the car's advantage.
I don't see how anyone could possibly disagree with that statement.
That said, I guess I'm one of the few here who prefers an A4 over a stick. Over the years, all I ever heard of was all the headaches and costly repairs that sticks go through because people don't know how to drive them properly. Also, driving a stick is like work to me. Keep in mind that I do a lot of city driving and get stuck in traffic on the freeway on occasion. Plus, there are other things that I like to do with my hands and my woman while driving. Whipping the car around a nice mountain side may be fun to some, but I'm more of a cruiser.
I like to drive slow so everybody can get a good look.
Old Jan 6, 2008 | 05:35 PM
  #46
Higgs Boson
Originally Posted by Higgs Boson
I can think of two instances where you might want to work the shifter yourself.
1 Up/down a hill for upshift avoidance/engine braking
2 Driving your auto on the road track/autocross and avoiding a mmid corner upshift. (why are you on a road course with an auto????)
Well, I sure don't!
Old Jan 6, 2008 | 08:07 PM
  #47
wolfman04's Avatar
wolfman04
OD is automatically accessed when necessary by leaving the car in drive. To me, driving around in 3rd is just wearing out the transmission unnecessarily. The car knows what gear it should be in which is why its called an automatic. The tranny is too expensive for me to be trying to second guess the engineers.
If shifting gears is so bad how comes GM put paddle shifter in Auto. C6
Old Jan 6, 2008 | 08:16 PM
  #48
Junkman2008
I've got a better question. Why isn't there a paddle shifter in the C5 A4, the car in which this thread is addressing? Do you think that the C6 tranny is exactly the same as the C5? Do you think that no engineering went into the C6 tranny to make it better than the C5? In your comparison, you must compare oranges to oranges in order to have a valid point.
Old Jan 6, 2008 | 08:28 PM
  #49
Dominic Toretto's Avatar
Dominic Toretto
If you want to move a shifter around while you drive, get a stickshift!
Precisely, which is why I got an A4 .
Old Jan 6, 2008 | 08:53 PM
  #50
CharlieB1979's Avatar
CharlieB1979
Wow...all that I really meant was if it was okay to Race while it's in "3" to be honest..and was wondering if doing so in "2" or "1" was a wise idea...which obviously it isn't. In my past Automatic cars i've only used the "2" and "1" gears for snow and such where I can drive slow and careful and well under speeds.
My second question was if it's cool to drive with it in "3" and then let go of the gas..push the gear into "D" to let it go into overdrive?
  #51
Higgs Boson
Not only is it a 6 speed instead of 4, the internals are different, more advanced and the ECU is programmed to understand what to do when in a manual shift mode. The valve bodies are different, etc. It's a totally different setup!
But, in the end, paddle shifters on anything but a clutchless manual (NOT an automatic) are just marketing gimmicks.
Old Jan 6, 2008 | 09:16 PM
  #52
Junkman2008
Old Jan 7, 2008 | 12:02 AM
  #53
Bluefire's Avatar
Bluefire
It is fine to do that and, you don't even have to let off of the gas. You can do it at WOT if you wish. I would imagine that there are a few A4 drag racers that push the lever into D, just after they cross the finish line.
Old Jan 7, 2008 | 01:50 AM
  #54
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
I rarely use 1st or 2nd in my A4. I do like to control my car in certain situations such as entering a freeway or passing on a two lane highway, so i almost always shift into 3rd in these circumstances.
If I just floor it in "D" i have little control and know I'm going for a ride when it kicks in. By shifting to 3rd i can use the throttle with good response and let off as needed and better control my acceleration with the throttle and the brakes....just my .02
I also believe I have more power both from the gears and the RPM as both increase the torque at the wheels. I have also notice that my tranny temp. runs higher at highway speeds in 3rd and as you probably know high temp. is a killer of tranny fluid.
Old Jan 7, 2008 | 08:24 AM
  #55
VET IT B's Avatar
VET IT B
I find myself using nuteral when I come up to a light. Some of the intersections here have a long waite in between lights. In nutral I don't need to use the brake so much. What do you think? Mark
Old Jan 7, 2008 | 08:28 AM
  #56
Junkman2008
You can't hurt anybody being neutral, but nuteral might hurt a bit!
No, you're okay in neutral!
Old Jan 7, 2008 | 11:10 AM
  #57
Mr. Azrael's Avatar
Mr. Azrael
Quite the opposite is true. Most automatic transmissions, and even the 4L60E, are rated for shift (number) lifespans. Driving in OD allowing the transmission to shift into OD for better fuel consumption causes the transmission to shift, shift equals friction, friction equals heat, heat kills transmissions. Driving in OD in town makes the transmission shift in and out of OD quite often, and each shift shortens the lifespan of the transmission. It is safer and causes less wear on the transmission to drive in "3" because it is not trying to shift back and forth into OD all of the time and will actually hold the gears longer and shift a little firmer; all good things for transmission life.
GM makes these cars for a variety of people, and the 4L60E slips its shift much more than it needs too (which makes it shift smoother) but ultimately creates much more friction/heat/shorter life span. It is always better to drive a vehicle in town with OD off, for the life of your transmission. Remember that all manufacturers use this OD shift at low speeds as a fuel saving measure, but it also lowers the service lifespan of your automatic transmission.
BTW, the OD band is weak in the 4L60E so WOT shifts can easily burn the band out. When going WOT even at highway speeds it is better for your transmission to be in "3". Generally unless you are more worried about saving fuel, and not replacing the transmission, drive in "3" for speeds less than 65-70mph.
