Coolant change: Need Help!
Old Jan 5, 2008 | 02:59 PM
carpe dm's Avatar
carpe dm
Default Coolant change: Need Help!
I want to drain the radiator, and change my coolant. I tried to open what I assumed was the pet-**** on the bottom, passenger side, but NOTHING will come out! What is the secret? The cap was off, the car level, and I could not get the thing to drain. The white nylon **** seems to turn to an open notch, and then just turns without going anywhere. ANY help would be appreciated, either here or in a PM. Thanks.
Old Jan 5, 2008 | 03:08 PM
hotwheels57's Avatar
hotwheels57
The white plastic 1/4" female "drain" is only a quarter turn as I recall. It might be faster (if that's your goal) to just remove the lower radiator hose.
Old Jan 5, 2008 | 03:15 PM
MrEldo's Avatar
MrEldo
I always found it faster to remove the lower radiator hose. Makes ahelluva mess though...
Old Jan 5, 2008 | 04:07 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You need a 1/4" extension to open it and theremove the coolant tank filler cap yo allow air in to the system to drain.
Old Jan 5, 2008 | 04:12 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Then I used pressurized air from a shop blower thing to force the rest of the coolant out by making a seal with my hands
Old Jan 5, 2008 | 04:38 PM
carpe dm's Avatar
carpe dm
Thanks guys. I've been doing this stuff for many years but have never had this problem.... I'll try again and then do the hose thing, but I know that will be a real mess. Appreciate the help.
Old Jan 5, 2008 | 09:09 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Be careful not to turn the drain more than about a 1/4 turn or it will break. Pull it towards you as you turn it.
Old Jan 6, 2008 | 01:44 AM
INaband's Avatar
INaband
CI 7-8 Veteran
The nipple on the drain, fits into the slot as you turn it 1/4 and pull out..I agree it's weird, I almost broke mine until I looked closer and figured it out..
Old Jan 6, 2008 | 12:19 PM
carpe dm's Avatar
carpe dm
Thanks; I will try again...... appreciate the help.
To Coolant change: Need Help!
