[Z06] functional real spoiler?
Old Jan 5, 2008 | 09:23 PM
White_Lightning's Avatar
White_Lightning
Default functional real spoiler?
are there any tested to be functional rear spoilers? I know carvaggio has a small rear lip/wing but does it actually provide any downforce?
thanks in advance.
Old Jan 5, 2008 | 10:25 PM
BitViper's Avatar
BitViper
Technically speaking..any wingshapped spoiler would be functional...jdo a degree....
BUt I know what you mean....
Old Jan 6, 2008 | 02:07 AM
White_Lightning
let me be more specific.
Tested.. For instance actually asisnt in keeping the rear planted at high speeds.
Old Jan 6, 2008 | 11:39 AM
BitViper's Avatar
BitViper
Sorry...I was being a ********...
I have never seen any reports on this...it would be intresting to find out what measuarable effects the current avaliable body bods have on car stability and traction
Old Jan 6, 2008 | 03:17 PM
zsnnf's Avatar
zsnnf
Or even a testomonial like "I could run 60 mph thru turn 1 but now with product x I feel comfotable at 65mph"
Right?
Old Jan 6, 2008 | 03:30 PM
vms4evr's Avatar
vms4evr
Kerry Hit makes functional hardware that is wind tunnel tested.
http://www.corvetteracebodies.com/
The Lingenfelter stuff is supposed to be aerodynamic.
This has been discussed quit a bit in the track section. Go over there and do a search.
Old Jan 6, 2008 | 03:33 PM
AU N EGL's Avatar
AU N EGL
YES and NO. For a rear spoiler to be functional, it should stick up at a 45*- 50* angle from the deck lidand no taller then 1.5" to provided down force over 80 mph.
The rear spoiler is to 'spoil' the air flow.
Chevy found that the small rear spoiler on the C6Z was just as functional as the full deck width spoiler that is the after market part
Old Jan 6, 2008 | 03:36 PM
AU N EGL's Avatar
AU N EGL
Right?
Close.
with my 2" front spilter, 1" rear spoiler and 3/4" wider rear fenders I can take a particular corner at 85 mph vs 70 mph with the same tires.
Now the down side is my TOP speed on a particular road ( track) has gone from 150 mph to 145 mph at the same red line.
The spoilers and splitters provide more down force, but also more aerodynamic drag and limits top speed.
Old Jan 6, 2008 | 03:39 PM
AU N EGL's Avatar
AU N EGL
Most of that info is closely guarded info. Unless you race and have a relationship with GMPP.
The info on Kerry Hitts ( ACP ) web site is very good.
Old Jan 6, 2008 | 05:54 PM
vette6aut0x's Avatar
vette6aut0x
Originally Posted by AU N EGL
Close.
I dont understand the mph difference with the rpm being the same. Could you tell me how that is?
Old Jan 6, 2008 | 05:57 PM
AU N EGL's Avatar
AU N EGL
DRAG. Aerodynamic drag from the front splitter and the rear spoiler.
The car is faster on straight WITHOUT the spoiler and splitter. but slower in corners.
the car is much faster in corners WITH the splitter and spoiler. Overall lap times are quicker as most road course are high speed turns and corners, not long straights.
My next aero aid would be an extractor hood.
Old Jan 6, 2008 | 08:04 PM
zulatr's Avatar
zulatr
[QUOTE=AU N EGL;1563498582]DRAG. Aerodynamic drag from the front splitter and the rear spoiler.
QUOTE]
as noted above, your RPM would have to be less assuming you're in the same gear.
yes, aerodynamic drag will reduce speed, as you stated.
mk
Old Jan 6, 2008 | 08:58 PM
Higgs Boson's Avatar
Higgs Boson
Uh, the only thing that can change an RPM:MPH relationship is gearing. Are you running a track wheel/tire setup that is a different diameter than before? That would change your gearing.....
You can't be going a slower MPH at the same RPM..... Drag will cause your car to not be able to power to a higher RPM at top speed.
What gives, dude?
Old Jan 7, 2008 | 01:17 AM
imflyinbiya's Avatar
imflyinbiya
What gives, dude?
Old Jan 7, 2008 | 01:30 AM
striper's Avatar
striper
The Caravaggio spoiler might actually provide some downforce without creating too much drag. The reason I say possibly is because originally these spoilers, front and rear, were designed by John Cafaro, who designed the C5 Corvette, while he was working on the car itself. He decided to take the designs private, I guess GM wasn't going to market them. He then sold all the molds to his "skunkwerkes" pieces to John Caravaggio, who now sells them under his own name. I followed the progress of these parts since the time when Autoweek first featured John Cafaro's customized cars while he was on the Vette project. I have both the rear spoiler and the front canards on my Z06.
Old Jan 7, 2008 | 02:57 AM
TheDVS1's Avatar
TheDVS1
And the larger "wings" also "spoil" the looks!
Old Jan 7, 2008 | 08:09 AM
AU N EGL's Avatar
AU N EGL
What gives, dude?
That may have beenn it. slightly lower PPM do to aero drag.
Tires were the same. Too busy at that point to look at the tach.
To functional real spoiler?
Old Jan 7, 2008 | 08:14 AM
Higgs Boson
no doubt!
Old Jan 7, 2008 | 08:43 AM
Jeffyvette's Avatar
Jeffyvette
Default You think so
Does the spoil the looks on my Race Vette (blue one in sig)? It sure make it handle well.
Jeffy'
Old Jan 7, 2008 | 10:09 AM
QKSLVRZ's Avatar
QKSLVRZ
Just a note on rpm/mph with downforce.
If you make enough force to compress your tires you'll go a little slower at the same rpm.
Now it might be so little it's hard to measure, but the circumference of your tire will actually be based on the distance from the axle centerline to the ground, which can change some.
